ptwob134
SOLD!
UPDATED 12/14 @ 19:00 AFTER FIRST "SALE" FELL THROUGH: I'm selling my 2003 Golf GLS TDi, silver/charcoal interior, 164,0XX miles, manual, new TB at 160K miles, located in Pittsburgh (Plum Boro), PA 15239 (got a Sportwagen due to bigger family size). Asking $5500.
The Bad:
- Passenger front fender dented due to a low-speed incident with my wife's SUV in the driveway. Purely cosmetic, about two years ago, zero rust on the creases.
- Poorly touched up scratches on the rear hatch, and a 1" dent on the passenger rear door plastic trim. Both these were on the car when I bought it. Miscellaneous other small scratches and chips consistent with a 7-year-old vehicle. Paint still waxes up very nicely though.
- Passenger front door doesn't always open from the outside because the cable from the handle to the latch mechanism needs adjusted or put back onto the mechanism. Been this way since I cut the wires to the microswitch for the interior lights after it started staying on about two years ago and I didn't have time to do it. Easy but time consuming fix.
- MIL is on for #3 Glow Plug and I've narrowed it down to needing a new harness, haven't got around to it.
The Good:
- Timing belt and all accessories changed at 160K miles by John Andriezewski in New Jersey this August, have receipt. The old water pump had a rare premature failure, hence the off-interval change.
- Panzer plate, EGR delete, homemade CCV filter, aftermarket taillights (due to a cracked driver side lens) all installed
- MAF changed out in July after original one degraded/failed
- Glow plugs changed out in August for troubleshooting MIL and routine maintenance.
- Always ran correct full synthetic oil
- Used recommended amount of DieselKleen on 95% of fill-ups for the last 100K miles for no good reason other than overkill preventive measures.
- Has sunroof, Monsoon sound, working heated cloth seats
- Mufflerectomy, glasspack with nicer tip installed
- I'll throw in my Bentley manual and timing belt tools less the crank lock that I lost, for a full-price purchase (will sell separately otherwise AFTER the car is gone).
- I have most of the receipts for stuff that go with the car.
- Clean Pennsylvania title, I own it outright
- Valid Pennsylvania inspection good through 8/2011
Other Stuff:
- Both front fenders, hood, grille and radiator were professionally replaced and repainted after I rear-ended a guy at low speed in 2007. I have receipts.
- Alternator replaced in 2007 after it threw a pulley at 90K miles.
- Tires are Walmart no-names, probably have at least 10K left on them (30K+ on them now).
- I am the second owner, bought used from VW dealership in Allentown PA in 2006 with 48K miles on it. Previous owner was allegedly a retired German couple, I have all dealer maintenance records from my purchase.
I got the car starting and running reliably now (original non-start condition was due to completely dead battery being caused by my new GPS left plugged in 24-7 slowly draining the battery - I can explain in graphic detail if you're interested but it starts/runs normally now even after three days outside in 15* nights). Weather permitting I will run it through the carwash and get a few nicer pics hopefully Sunday.
Based on the fact that this is now a running car I have updated my asking price to $5500. Yes I might be able to get a little more but I think that's a fair price and I want to move it ASAP (2 drivers + 3 cars = unhappy wife!). Not to say I'm not open to fair discussion but don't expect to get it for free. Please email me at sdchanoski@yahoo.com as I don't get to check here as often as I do email. Thanks for looking!
Sam Chanoski
The Bad:
The Good:
Other Stuff:
Sam Chanoski
