Blair
I checked my front brake on my 2000 tdi Jetta . I notice that the inner left pad was getting down so I removed the caliper . The sensor that works the worn pad is connected on this pad . How do I disconnect the wire from the connector ? I tried to pull it apart at the joint but it seems connected inside . any suggestions ???
