CentralOregon
I put in a manual boost valve and followed the instructions from the boost valve manufacturer, works great, but every 30 miles of so I get CEL & 00575 (manifold pressure differencial code) or something like that? I know it must be due to the overboost from the boost valve but what can I do to keep the CEL from lighting up? Do I need a chip retune, ECU reprogram or is there a special way you need to run the vaccum/boost hoses on the TDI (A3 wastegated not VNT)?
Currently the manual boost valve is between the waste gate actuator vaccum canister & the N75 (like I said manufactures generic "one size fits all" install instructions).
Thanks,
B
Thanks,
B
