jimbote
Certified Volkswagen Nut
I have an extra DB line and block fitting....do you want a mani also?
PM sent, thanks jimbote!I have an extra DB line and block fitting....do you want a mani also?
I've researched a lot of parts suppliers, specifically avoiding Chinese crap.
On the way is a new crankshaft rear main seal, oil pan gasket, and water flange o-ring (for the flange I found at Hansdieselparts.com that
hansdieselparts.com aka vwdieselparts.com...aka peter rothenbacher...rothenbacher "engineering" .... from the hansdieselparts website front page ..... and Aftermarket Parts made in USA, Germany, France, Hungary, Brazil, Spain, China and Taiwan.You realize what you just did, don't you ?
lmao...yeah we are tuff on ya'..... sheesh I wonder how many friggin TDI's that crook has had a hand in destroyingYou guys are on it. I erred in my earlier post. En route from Rothenbacher/Hansdiesel/emiata is a German-made coolant flange that comes off the head at what will be my firewall - I have the original with coolant glowplugs that I can mod jimbote-downpipe-style if need be. The Chinese parts from them are likely the 2 GT15 turbo gaskets and an intake manifold gasket. That is it. Crankshaft rear main seal is from discountvdubparts.com and is Victor-Reinz.
I may be wrong, but those two gasket sets should work fine for long enough.
The boraparts Oldpoopie kit, Rosstech's software and factory repair manual (hey, I should have gotten this awhile ago, who knew?), Viton fuel lines and IP seals and rings, down to my shop rags are German or made in the US (huh, I guess we are still making things - good for us )
I love wiring!
My sensors are on the driver side. The only thing coming out of the back is a coolant line that goes to the heater.There will be just barely enough space between the firewall for the oil pressure sensor and coolant flange coming out of what is now the back of the head.
dang...I love cali....I'll be swingin' your way in the yota sometime this summer/fall ...we'll have to meet up !!Wow! 19" woo! woo!
We've had over a foot of RAIN here (measured in a jar outside). A true monsoon!
To top that off, a 75' oak tree just fell, missing our pump shed by inches.
Well, good day to curl up w/ a book....
I was thinkin' the same thing yesterday!!at this rate in a couple of years there will have to be a tdi-yota fest. which would be fun wouldn't it!!
Ha ha ha, jimbote, imtryin, couple of years seems right on, some days... Yota TDI gathering definitely in order.at this rate in a couple of years there will have to be a tdi-yota fest. which would be fun wouldn't it!!
