***dsm001***
As my BLS engine almost throw a rod trough the block i need to replace the engine. The engine did almost 150k kms. I have found an ASZ engine with only 40k kms on it and it will be swapped. Can the engine straight fitted in the car, just to make a hole for the crancksensor and a few small other mods or does the camshaft also need to replaced by the bls camshaft (the bls have a DPF camshaft and the ASZ not) but the DPF will be removed and and exhaust without DPF will be placed.
As the ASZ have 130 injectors would it work if the car will be remapped later as the ASZ engines can take easy 180+ bhp.
The DMF and clutch were already replaced by a SMF and a valeo clutch in the past. Would these clutch hold the 180BHP ?
What turbo would be a great upgrade for this car ?
