Old November 5th, 2018, 18:44   #1
laminated
Default vag mod worth doing
was in a 15 with this mod, makes that flat spot disappear in the accelerator
[Direct Acceleration - Throttle response]
With this mod, you can change the behavior of the accelerator. Option B provides a more linear acceleration without sudden deliveries.
1 - Module 44 - Power steering. then in security box enter Code (19249) after that
2 - Adaptation
3 - Select - switching driving profile
Choices :
A - Gradual, controlled by time
B - Directly controlled threshold value
laminated is offline   Reply With Quote
Old November 5th, 2018, 19:58   #2
Grigg3
This made my manual drive more predictable, when shifting can now manipulate the throttle, matching speeds for smooth gear changes like in the older cars. Like it should be.
I wondered if MPG would suffer and seems to not have bothered it at all, at least with my driving style.
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
Old November 6th, 2018, 05:53   #3
740GLE
best 10 minutes with a laptop . . . ever
Old November 6th, 2018, 06:20   #4
oilhammer's Avatar
Fuel Economy: fantastic
I agree, it makes a noticeable difference.
www.cardocautomotive.com
Old November 6th, 2018, 07:06   #5
sands80
Fuel Economy: 46.4mpg
I've heard about this mod - just curious- why does this setting come standard from VW - what is the purpose of a non-linear throttle for the everyday driver?
I had assumed that the speed and the responsiveness of the TDI was slow (because it was a diesel).
sands80 is offline   Reply With Quote
Old November 6th, 2018, 07:49   #6
oilhammer's Avatar
Probably because they do not want unintended wheelspin on a small FWD car with a small V8's worth of torque on tap not much off idle.
There are LOTS of modern cars that nerf the output of the engine at lower speeds and/or in lower gears.
This is why my old VAG diesels were so fantastic in the snow, even just being FWD with no locking diff or traction control of any kind. With only 52hp and around 85tq, it simply didn't have the power to spin the tires, even in snow. It just slugged right on through like a yak.
Old November 8th, 2018, 12:27   #7
mopower
TDI(s): 15 GSW
I'm adding this to my list of things to try next time I have access to the vagcom!
mopower is offline   Reply With Quote
Old November 8th, 2018, 13:51   #8
The Tortoise
Throttle Response + Starting Vibrations + Dynamic steering are the holy trinity of Mk7 Vag-Com/OBD11 changes.
The Tortoise is offline   Reply With Quote
Old November 9th, 2018, 05:20   #9
740GLE
My only guess for that extra .5MPG by smoothing out response. EPA numbers are key.
Old December 4th, 2018, 08:54   #10
sohccammer427
sohccammer427's Avatar
Fuel Economy: ?~45~?
Does anyone know if this mod is programmable on a '15 Passat EA288? Mine is also a six speed.
If it is, I have a a vagcom and will try it.
If hammer give it a thumbs up, it's worth looking into.
2015 Passat TDi SE 6 Speed Manual
2017 Chevy Colorado Duramax
sohccammer427 is offline   Reply With Quote
Old December 10th, 2018, 07:41   #11
Divinitous
TDI(s): None Yet.
Buyback'd in my '12 TDI for a '15 TDI and was really disappointed in the car. Almost to the point where I would be itching for the warranty period to expire so I could get a tune.
That was until I did this FIX. Big change in the car and how it drove. To me it drives about the same as my '12.
Divinitous is offline   Reply With Quote
Old December 10th, 2018, 08:54   #12
740GLE
I'd have to wager its not, reports of it not available on a '15 Beetle which is based on the Jetta electronics, which the Passat is in similar boat.
That being said, a tune with it's negatives, def puts some boogy in a '15 Passat.
Old December 11th, 2018, 06:13   #13
sohccammer427
I did give it a try, was able to navigate to the security code input screen but the code 19249 was invalid. Referred me to the service manual for a valid code.
Old December 11th, 2018, 09:52   #14
Lightflyer1
Lightflyer1's Avatar
That was my experience with my 2015 Beetle as well IIRC.
Old December 12th, 2018, 04:34   #15
Growler
Got Soot Vendor
Growler's Avatar
ill add this to my list of things to do with VCDS after I get my car back from Phase 2 next week.
2 - Adaptation
Choices :
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
A Mod worth doing SVTWEB VW B5 Passat TDIs 16 September 23rd, 2009 12:36
Air Intake Mod - worth it? NewTdi TDI Power Enhancements 5 November 28th, 2004 12:58
How do you make VAG-1552 do VAG-COM adaptation mod triggerman VW MKIV-A4 TDIs (VE and PD) 4 October 17th, 2003 07:02
is vag com worth it A4tdi110 TDI 101 9 April 9th, 2003 19:44
VNT mod is it worth it?? Rick TDI Power Enhancements 22 February 23rd, 2000 16:44
Page generated in 0.16608 seconds with 13 queries
[Output: 126.68 Kb. compressed to 105.42 Kb. by saving 21.26 Kb. (16.78%)]
