Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old October 28th, 2018, 19:10   #1
Dizzy.618
TDI(s): 2000 Golf
Fuel Economy: 41 Auto
Default TDI knocking
My 1.9 with 378k has started knocking ratteling but runs ok. Now has check engine code.
Dizzy.618 is offline   Reply With Quote
Old November 5th, 2018, 12:30   #2
HamtramckDiesel
Fuel Economy: 48.7 mpg
Have you tried any type of scanner on it? lol
HamtramckDiesel is offline   Reply With Quote
Old November 6th, 2018, 05:31   #3
k_pt
k_pt's Avatar
TDI(s): VW MKIV TDI
Check injector values with VCDS.
Pull the valve cover and check camshaft and lifters.
Follow me on some mechanics works https://www.instagram.com/kptgarage1986/
k_pt is offline   Reply With Quote
Old November 6th, 2018, 11:11   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Use a stethoscope or hose-in-ear to isolate the sound. Valve cover or Injection Pump most likely culprits.
BobnOH is online now   Reply With Quote
Old November 6th, 2018, 14:00   #5
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Just throw some new pistons, rings, connecting rods and bearings, crankshaft and main bearings, cranks seals, oil pump, a rebuilt head, injection pump, and some new injectors in it and the sound should go away.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is online now   Reply With Quote
Old November 6th, 2018, 16:21   #6
Lightflyer1
Lightflyer1's Avatar
When was the timing belt last changed and who did it and what all was replaced?
Old November 7th, 2018, 10:50   #7
k_pt
k_pt's Avatar
TDI(s): VW MKIV TDI
Probably ... but I've seen mechanics replacing the whole suspension over something rattling on the glovebox ... so ...
2.0 tdi knocking sound dainelb3 Audi A3 3 July 13th, 2016 19:23
Help pls identifying engine knocking (or hopefully clutch knocking) noise tothemax TDI 101 25 July 21st, 2015 08:16
06 TDI Engine Knocking tramic86 VW MKV-A5 Golf/Jettas 52 August 12th, 2014 10:47
bora tdi knocking need help paulyg General VW Discussion 3 June 8th, 2012 13:33
Unbearable knocking noise 1.9 TDI Bazrippa TDI 101 8 December 3rd, 2009 00:43
Page generated in 0.15677 seconds with 13 queries
[Output: 79.49 Kb. compressed to 68.76 Kb. by saving 10.73 Kb. (13.50%)]
