So ive done a stupid thing and gotten my self an Audi a6 (2002), with the non reliable V6 tdi, (code AKE) maiinly as a winter beater but will see
So onto the problem, there's little throttle response whenever i floor it, but if i have about 30% throttle it will start to pull after i little bit. Its an Automatic so i use manual mode to get it to pull better, but this is bugging me
Ive swapped over thr wastegate from my parts car which is an 2000 A6 V6 tdi, it made it a bit bettet but not much
I also have s fault on the injector with the wire on, could tjis be the cause? Ive seen people tell me its tje injection pump is wrongly timed (as it has new cams, and drive belts)
With that if i sit around 2000rpm and slowly increase throttle it will pull, but if i floor, its lazier than a 1,8 Celica
Any suggestions?
Any suggestions?
