Ronstarman
I have two fans on radiator.One is for A/C,and other for Radiator cooling.I am under the assumption,(the mother of all f-ups),that both run separately or do they run as a team in the warmer weather?
I did notice the A/C motor the smaller of the two wobbles like the shaft is bent.Is there an aftermarket fan motor or can I purchase one from an autoparts store? And how do I know the fan motor for radiator works.I don't have any way of checking other than the temp gauge which goes to 190 and not any higher.
I have another question as well and it is about the size of a battery.I have a early 99 Jetta 1.9 TDI turbo and the CCA says 730? Can I go with same size battery with a higher CCA? If so,it will not hurt anything will it? Your answers help me out for a person with limited pocket money and just starting out with diesel cars
Ron
Ron
