Oldman
- Joined
- Feb 3, 2001
- Location
- Leander,TX,USA
I've had the 11 mm in twice; both times the car was in identical configuration:
Timing set to middle of graph, 62/110?, .205s, 2.5 inch euro cat downpipe, chip, 11mm pump, K&N filter, power server (last year's version without cetane).
The first time I was running on plain cheap pump gas, power was very good, but the smoke was BAD, real bad. I had the stock VNT setting. Even slow acceleration would produce gobs of smoke. It felt stronger than all of the above and the high pressure A4 10 mm pump but not LOADs stronger. The setup lasted about a month and there was just too much smoke in all modes of operations. It was summer so temps were in the 100s.
This time I'm using the above with -1 VNT twist, the newer power serve with cetane boost, Texaco premium diesel, D'Geek short shifter and D'Geek cooler.
I can say smoke it way down, I no longer have the 1/4 throttle smoke, I have to go 1/2 throttle or more to have smoke. Throttle response in all gears is unbelievable, just a slight pressure and she is moving. 1/2 throttle in first gear can break em loose. When it is cold out I can slip the clutch with as little as 1/4 throttle in 4th or 5th,
How does it rev? It revs like a gasser, no really it does, I shift at 4500 rpm and by the time it is said and done the tac is close to or over 5000 rpm, Pre 11mm pump the car would lay down after say 3800 rpm, this one pulls no problem to and past red line, if you are not looking at the tac you will overshoot the redline by a large margin.
Boost, pre pump it was the typical Upsolute with .205s, I've have boost overshoot and then it would settle for a nice 18 PSI to about 3700 rpm or so and decline to 14 to 16 PSI at 4500 rpm, it would never keep a steady 18 PSI to redline.
Now, I have bout the same or a little more overshoot and it settles to the 18 PSI or so, but get this: boost rises to about 19.5 PSI and stays that way as long as I want to hold it, which is up to and past redline. I'm going to try -2 VNT just to keep overshoot to a minimal.
Smoke at WOT is heavy and it is black, leaving no doubt that this is a diesel. At least is NOT all the time under all conditions.
As this is Texas, I think smoke will be back big time during summer heat. My next plan is to up the intercooler, I would like to know if somebody can get me a good boy price for the left side TT intercooler, the hoses from one to the other, I of course don't need the manifold, unless somebody wants to send me the SDI one which should be no problem plumbing into the second intercooler.
http://store6.yimg.com/I/machvw_1677_5417124
http://www.machvw.com/golivadsidin.html
I wanted a Forced performance cooler, but after some thought, I figure I need a really big intercooler. Greddy has also advertised a large front mounted intercooler and this should free up a bunch of stock intercoolers from 1.8T and maybe even a few TDIs.
Overall I'm happy with the upgrade. I've given up on the warranty and I've fixed all the broken stuff including: glove box, arm rest, cup holder, water pump, tensioner, serpentine belt, serpentine belt tensioner. Thanks to D'Geek, he that good. I need a clutch but gotta pay for lots of stuff including income tax coming up and a 6 week to Japan / Hawaii.
http://www.dieselgeek.com/
