charlie_s
My 2004 Jetta (BEW engine) makes a horrible noise when I turn the steering wheel at low RPM. In addition, the belt tensioner was really vibrating, probably a 1/2 inch or more. I read many posts about the alternator pulley being the most likely problem. When I checked the pulley operation by sticking a screw driver through the housing to prevent the fan from spinning, it would not move in either direction. So I guess the clutch is frozen? Most of the other posts described a problem with the pulley where it would turn in both directions, so not what I am seeing. Anyway, I went ahead and ordered a new pulley and the newer tool from IDParts (one piece tool). Unfortunately, someone before me must have tried too hard to get it off in the past, because the toryx bit would not hold. I removed the alternator and can see that the splines on the nut holding the pulley on are almost gone (the toryx driver gets stuck in there when I turn it much at all).
So my question is whether this type of pully problem would result in the tensioner virbrating so severely, or is it the tensioner itself? Other than the belt/tensioner vibrating, and the horrible noise when turning the steering wheel, I was never getting any signs that the alternator wasn't working right.
