JDSwan87
Black Swamp Thing
- Joined
- Feb 9, 2014
- Location
- Michigan near Toledo
- TDI
- 2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
Hi,
I'm having stumbly smokey cold starts on my 2001 ALH. Mods are 11mm IP, PP520 nozzles, STOCK turbo and a Malone Stage 3. I have a Stant 195*F thermostat installed in it also. I previously had the IQ set at 6.8 (was told to by tuner). I woke up this morning and checked the group 7 temperatures with VCDS before start up:
Fuel temp: 10.8*C
Intake air temp: 9.0*C
Coolant temp: 10.8*C
I also checked group 12 glow plugs, those readings before start up are:
Glow period preheat: 2.02
Supply voltage ECM: 12.16V
NOTE: Glowplug time was extended with VCDS before last winter.
Then I took her out for a drive to get her up to temp to check timing. Timing graph is below:
I also reset the IQ back to stock value of 32768 to put IQ at 4.0 when fully warmed up.
Today's startup wasn't smokey but it did stumble for about 2-3 seconds before it smoothed out.
Group 7 readings after fully warmed up were:
Fuel temp: 29.7*C
Intake air temp: 30.6*C
Coolant temp: 100.8*C
Any input??
Fuel temp: 10.8*C
Fuel temp: 29.7*C
Any input??
