A
ackumar
Guest
All,
Looking for some help on timing belt replacement on 2002 Jetta TDI
Summary of the story: I didn’t have the right Cam locking (dummy me bought the wrong one A3) plate so instead of waiting and getting the right one I decided to carefully mark the CAM and injector pump before removing the old belt. I put the crank at TDC and everything seemed to be aligned as instructed; marked the CAM and Injector. I went ahead and removed the old belt and put a new one on. After putting the new belt on I cranked the engine over number by hand and everything seems fine; finished the install process, started the car. I seemed to run fine but after driving it around the block It seems like it does not have the same power and pull that it use to have. Few minutes later, the check engine light came on. I shut the engine off and restarted it and the light went off. But after another few minutes of driving the light came back on again.
Question is:
Do I need to redo the entire process of timing belt with the locking plate, pin and remove the cam or just reset the injector timing with this VAG-COM software?
Any help/suggestion is greatly appreciated.
-Arvind
Question is:
-Arvind
