CnCBuss
Hello Forum members,
I don't post very often here but I sure appreciate my membership.
I'm having a recurring issue with my 2000 TDI Jetta. It's got over 300,000 km's on it and is normally always reliable and starts every time. I've kept it maintained as required.
Except for yesterday, I got in, cranked the engine, started it up and after about five seconds of running normally, just stops. The engine can then be started up again but dies again within 2 or 3 seconds. Using the pedal has no effect. No matter how many times I start it up, it just dies after few seconds. Cant keep it running.
This is not the irst ime I've had this issue. It's happened only one other time during a very cold snap (-30_c) and I had to get my car towed to a garage. After sitting for two (2) days in a heated garage, it started fine again and we did not experience the problem since then, over six (6) months ago.
It almost feels like an electronic problem, but I can't be sure if it's engine related or a problem with the key switch. I
So I'm turning to my fellow TDI members to9 see if this is a common problem and how to fix it. I do a little maintnan myself, but I won't tear things apart too deeply.
Thanks for any and all advice.
