HowieE
I am back in the game with the purchase of a 2015 Passat TDI stick shift. I want to set up a 12 receptacle that is not ignition controlled for a towed vehicle brake system.
Does anyone knew where I can pick up the wire, and color of wire, that feed either of the 12 volt receptacles currently in dash or center compartment and feed them with a new none ignitioned fuse? Or it easier to just install a new separately fused receptacle?
