NB_TDi
http://www.ross-tech.com/vcds-lite/download/index.html
This is the link to the newest version VCDS Lite.
If you get it to tell you injection timing, share it. My version of 4.09 will not give injection timing, I tried.bashoro said:So I think I have scoured the Ross-tech site sufficiently in search of this demo version of 409. I think I may be confused. Is there an actual free demo still available to download and use? If so where is it on the site? If it's on there it looks like it is hidden well. I am rolling in a 2002 jetta. I need to look at my injection timing.
Because eBay cables really aren't "USB" cables. They're a Serial interface with a FTDI Serial<->USB chip shoehorned in somewhere.NB_TDi said:Nope, still no direct USB support. A FTDI driver still must be used.
Your car uses the CAN BUS system, not supported by the older style of cables like one finds on eBay. There is no legit 3rd party supplying a CAN BUS capable cable that works with Ross Tech's VCDS.Idahosnoman said:I have a 2010 Jetta Sedan. I am considering purchasing the ebay cable so I can fix the phone menu (This is just the reason for my purchase) on the MFI. I have looked at the Ebay cables and they say they are not compatible with CAN which I am sure my vehicle is. I would like someone to verify this, and possible link me to an Ebay cable that will link to my 2010 Jetta Sedan.
If this is not available, then I will possibly purchase the Ross kit if my dealer can't fix the phone menu.
What's the issue with installing the driver?Anyone have recent experience with these inexpensive eBay cables? I bought one, but I can't get the USB driver to install. VCDS-Lite installs fine. Suggestions? If anyone on the south side of Atlanta has a functioning Vag-Com setup and is willing to reset my airbag light ( I removed the seat and it came on), I'll buy you a beer or three.
You are asking a lot this being a forum.As I said before, please don't turn this into a cheap knock off cable bash. The cable I own is nothing more than a standard OBDII cable that came with nothing else. No CD, no drivers, no directions. So keep this thread clear for honest questions and comments.
Well, I finally got the driver to install by turning off the requirement for digitally signed drivers during the Windows boot process, and then using the hardware wizard to manually install the drivers. But it still won't work. I downloaded the most recent version of the Vag-Com 409.1 software and installed it, but when I try to run it, I get the normal mouse pointer "thinking" display like you get when any program starts, but then it goes away and the program does not load. I then downloaded VCDS-Lite. It runs fine, but when I do the comms test, I always get "Port does not exist, interface not found". I have tried every combination of physical USB port and COM port assigned. I can't even begin to tell you how frustrated I am.What's the issue with installing the driver?
You do realize that this entire thread, and the original post you quoted is from 2008, it's been a long while.You are asking a lot this being a forum.
Don't you know that whatever someone owns is the best and nothing else could possibly be as good.
Anyway, this should be a good read since I am into tech stuff.
Maybe some of this will apply to the circuit I built for my Porsche although I did buy the Durametric code reader.
It's more than likely the drivers yes. Where are you getting them from? Most, not all, are FTDI.Well, I finally got the driver to install by turning off the requirement for digitally signed drivers during the Windows boot process, and then using the hardware wizard to manually install the drivers. But it still won't work. I downloaded the most recent version of the Vag-Com 409.1 software and installed it, but when I try to run it, I get the normal mouse pointer "thinking" display like you get when any program starts, but then it goes away and the program does not load. I then downloaded VCDS-Lite. It runs fine, but when I do the comms test, I always get "Port does not exist, interface not found". I have tried every combination of physical USB port and COM port assigned. I can't even begin to tell you how frustrated I am.
This is taking a comically bad turn. I had already put the cable in the trash, but since you put the link right here, I grabbed it and tried the FTDI drivers. Not exactly plug and play, but it worked! So I plug in and I can talk to a lot of the controllers, like the transmission, etc, but not the airbag controller or the engine. Sweet. So I look on the VCDS website and they mention the Symphony radios can cause some issues. I don't see an easy way to pull the radio and reach the connectors to unplug it, so instead I pull the fuse marked telephone/radio. This does kill power to the radio. But, now the interface can't connect! Pop the fuse back in, connects right up. Awesome. Is there an easy way to reach the connectors on the radio or any other suggestions?It's more than likely the drivers yes. Where are you getting them from? Most, not all, are FTDI.
http://www.ftdichip.com/FTDrivers.htm
