Old December 15th, 2018, 15:03   #1
HOOPER65
HOOPER65's Avatar
Fuel Economy: Pretty Darn Good :)
Default Cant get oil filter off
2.0 L Gas ...
Literally broke a strap wrench in the process.
have to take to a shop now
just to get a filter off . . .
I did not re-fill it with oil - due to plan to rope tow up the street to shop.
however --- is the height of the oil filter such that it could be taken off
while oil is in the engine and not drain all the oil out through the filter port ?
I'm trying to avoid putting brand new oil in
only to have to be draining brand new oil out
just to get a filter off ... and then putting contaminated oil
that was dumped in a bucket - back in .
HOOPER65 is offline   Reply With Quote
Old December 15th, 2018, 19:50   #2
ShelbyRazorback
Make sure you are turning it the correct way. I've had to drive a screwdriver all the way through one near the base and unscrew it that way (long time ago, forgot the make of the vehicle). Make sure you go an inch or so away from the base so you don't damage it. I'm not sure how much room you have but the longer the screwdriver the better for leverage. Also use a thick screwdriver or you'll bend it for sure. Although if it is indeed on that hard, you may bend a thick one too so don't use a screwdriver that you are emotionally attached to.
ShelbyRazorback is offline   Reply With Quote
Old December 15th, 2018, 20:25   #3
[486]
TDI(s): 02 golf ALH
once you get it loose the upper cooler gasket will likely leak, at least that's my luck on them after they've been manhandled by idiots cranking filters on. Luckily you can use the old filter gasket on top of the oil cooler
I mangle them off with a channellocks, sometimes all of the can has to come off, then you use a chisel and hammer to spin off the baseplate
Old December 15th, 2018, 23:40   #4
Ol'Rattler
Ol'Rattler's Avatar
I would say, go ahead and remove the filter. The screw on filters from the factory are extremely tight so just deal with it. Perhaps you should not attempt something that is beyond your skill set.
If you did not damage the filter so that it leaks, just fill the engine back up with oil and drive it to the shop you had in mind.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old December 16th, 2018, 04:14   #5
HOOPER65
HOOPER65's Avatar
I've done hundreds of oil changes - On this occasion it was not me who put the filter on too tight - but I agree, there is a risk of this going from annoying, to a bigger problem if the cooler gets damaged in the process - so I'm likely going to fill it up with oil and just drive to the shop ( a VW shop ) -
- - - a parts place suggested the screw driver idea ... but not much room and its getting to could up here in the great white north to deal with a mess like that outdoors in my yard ( old dripping everywhere from a punctured filter ) .. . I'll head to the shop - that for the advice everyone.
Old December 16th, 2018, 14:44   #6
Ol'Rattler
Ol'Rattler's Avatar
There is no shame in stopping before you get to a point where you could FUBAR something and ruin your day.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old December 19th, 2018, 06:33   #7
TdiRN
Fuel Economy: 41-43mpg
Get the adapter with the 3/8 lug in the end of it. Fit it on the filter and put an impact on it - give it a couple of short bursts to break it free.
2002 VW Jetta TDI auto->5speed conversion, Malone Stage 1
2000 Ford Excursion XLT V10 - 5star tuner, Airbags, Rancho 9000s, HD 4r100 with shift kit
2011 F150 4x4 SuperCrew Ecoboost - 5star 93 octane/adaptive octane tunes
2017 Toyota Sienna XLE
TdiRN is offline   Reply With Quote
Larger Oil Cooler and Remote Oil Dual Oil Filter with By-pass Filter G60ING VW MKIII-A3/B4 TDIs 24 December 5th, 2017 15:33
Oil Filter Cap / filter problem? Wont screw, feels like filter too tall? BBB129 VW MKIV-A4 TDIs (VE and PD) 5 January 12th, 2016 17:55
K&N Oil Filter and Full Synth Shell Rotella T,how many miles before next oil/filter? BioNerd Fuels & Lubricants 24 June 27th, 2011 12:20
FS: Power Service, oil filter, fuel filter, air filter greg6.7 Private TDI Items for Sale/Wanted 2 September 1st, 2009 17:36
FS: Elf 5-40, MKV Oil filter, Fuel filter, Cabin Filter BTL Private TDI Items for Sale/Wanted 1 October 24th, 2006 15:02
Page generated in 0.13194 seconds with 12 queries
[Output: 81.76 Kb. compressed to 71.19 Kb. by saving 10.57 Kb. (12.93%)]
