Old August 28th, 2017, 07:32   #1
nikolay_ss
TDI(s): 1.9TDI ALH
Default VW MK4 ALH 2001 - Do I have CAN bus on the OBD2 port?
Hello,
I found some similar threads, but none of them was including the answer of my question.
When I connect to VCDS and click on test connections it says K1 and K2 are OK and CAN BUS says Not ready.
When I go to 19. CAN Gateway in VCDS it shows my CAN BUS and bla bla... everything seems okay. I also saw in 46. channel I think, can't remember correctly that Can bus is OK, but can I access it via OBD2 port or it's just for the instrument cluster if it's immo3, mine is immo2. I tried ELM327 and it works, but I want to connect there via arduino and can bus controller so I can make a small display and shows some info there.
Thanks for help!!
nikolay_ss is offline   Reply With Quote
Old August 28th, 2017, 08:00   #2
Enabled
Pins 6 and 14 of the OBD port are the CANBUS diagnostic lines, but MK4 did not have direct canbus diagnostics. VCDS needs to have a CANBUS car connected for the CANBUS test to work.
This doesn't mean that there aren't CANBUS connections from some modules to other modules. Common places to have a direct canbus is ecu to instrument cluster, ecu to automatic transmission module (if equipped), etc. But this is for internal module to module communication only.
-2003 Jetta TDI GLS Manual (Mods: SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned)
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car)
-BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon (Self tuned ~230hp)
Enabled is offline   Reply With Quote
Old August 30th, 2017, 06:09   #3
nikolay_ss
TDI(s): 1.9TDI ALH
Thanks for your answer.
So how can I connect to CANBUS and read the messages which are processing from one module to another? From where I can get the signal? Should I try to find the wires behind the instrument cluster and try to read from there?
Thanks!
Old August 30th, 2017, 06:18   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
What are you trying to do?
As Enabled's post says, that car has CAN, but DLC communications are done through the CAN Gateway, the CAN is just for module-to-module communication on that car. DLC communication is via the K-line setup.
There is also a paired wire communication dedicated for the CCM and the door modules (if equipped) and I think the radio might also be on this, not sure. The radios changed during these "internal CAN" years for our cars, mid-2002. The radio may also just use the K-line still.
I wondered about this once for diagnostic purposes. As I ended up finding out through process of elimination, I had a 2002 Jetta that had an SRS module that insisted the doors be unlocked. It thought the car was in a crash, or at least that portion of its post-crash logic was stuck on, so it kept telling the CCM to unlock the doors. And any lock signal given to the CCM (which it was getting, from all sources) was simply overridden. So somewhere in that CAN bus was a message packet being sent high priority (since SRS signals get this first) to the CCM.
But unless you have a mechanism to actually READ these packets, and decipher what they mean, I am not really sure what you could learn by monitoring the CAN bus directly. You can read voltages with a fast true RMS meter, but again, the packets are being transferred about so fast and so many that you'd need some way to know what it meant.
oilhammer
www.cardocautomotive.com
Old August 30th, 2017, 09:33   #5
nikolay_ss
TDI(s): 1.9TDI ALH
Hey oilhammer, thanks for your comment, it was really helpful.
I am trying to read my engine channels and display them to a screen which I will put into my instrument cluster. But from your comment I understood thats not possibl for my engine. So I should find a way to read K line and work with it, right?
Old August 30th, 2017, 10:12   #6
wonneber
If your trying to read the engine blocks (group 1 iIrc) you should not have a problem with VCDS.
If you replaced the radio with an aftermarket radio and it was not wired in correctly that could cause issues.
That's part of why I ran new power & speaker wires when I replaced mine.
Did you buy the real (not copy) VCDS cable?
Old August 30th, 2017, 10:49   #7
oilhammer
oilhammer's Avatar
Sounds to me like he just wants a Scangauge or similar.
Not sure about what is available for the car though, as Europe did not get OBD2 like we did until later. Up through 2003 I think they used EOBD, and the DLC was down in the center console. My 2000 Golf even has the spot for it down there.
oilhammer
Old August 31st, 2017, 02:48   #8
nikolay_ss
TDI(s): 1.9TDI ALH
Yes I can read the car's modules with VCDS, but I want to make a separate controller with a display and implement it into instrument cluster.
I found something that I think will work in my case. I need to test it.
https://github.com/ibanezgomez/FISBlocks
Old August 31st, 2017, 06:24   #9
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Let us know what you find. Having a probe at the CAN in the Jetta and Touareg has been on my list of things to fiddle with for a while.
-J
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old August 31st, 2017, 06:28   #10
oilhammer
oilhammer's Avatar
They make contactless CAN readers (a little box that goes around the paired wires) but I would assume this just reads binary 1s and 0s, and unless you have a way to decipher the language it would have to be attached to something else?
oilhammer
Old August 31st, 2017, 06:30   #11
compu_85
Gadget Guy
compu_85's Avatar
Yes, that's the idea. Hook it up to software to do packet analysis.
OBD2 Port - Can't catch a break... wildneg VW MKIII-A3/B4 TDIs 10 February 5th, 2017 16:04
OBD2 port stopped working Rayovac VW MKIV-A4 TDIs (VE and PD) 2 July 17th, 2015 08:41
on board computers VW Golf 2001 ALH Mk4 KeithOfOhio TDI 101 4 June 26th, 2015 10:14
OBD2 Port Fuse? 09R/T VW MKIV-A4 TDIs (VE and PD) 2 February 26th, 2010 16:44
Help with CAN Bus and OBD2 port not working after MFD installed justsmurph Upgrades (non TDI Engine related) 15 March 19th, 2009 14:05
Page generated in 0.15348 seconds with 11 queries
[Output: 105.69 Kb. compressed to 89.59 Kb. by saving 16.10 Kb. (15.23%)]
