Old September 20th, 2011, 22:23   #1
0Silva1
TDI(s): 2010 GTI DSG
Fuel Economy: 40+
Default Turbo Underboost
Hi all,
Been a long time since I've been on these forums. I used to run MK4 TDis but in the last year i've come into a MK5 (2006) which was working fantastic until recently...
Quick story. The car came from a one-owner, lady driven, always dealer-serviced and properly maintained owner. It had 227xxx kms on it when i got ahold of it. A few months after buying it, the transmission mounts broke and the motor dropped on the driver side. It was never the same.
Now, with a CEL code that reads turbo underboost, I've been struggling to get it back to normal. Here's the situation, normally the turbo would spool around 2000 RPM with a distinct whistle and noticeable pull. Now, the turbo doesn't spool until about 2500-2600, there is a minor whistle, and it seems verrrry lazy. Also, when driving on the highway at about 65MPH, if I come to a hill and need to give it about 1/2-3/4 throttle to maintain my speed, sometimes I will get limp mode. Now, when I shut the car off and restart it, limp mode is gone and I'm back to ^. This is extremely frustrating.
I am almost positive there are no obvious leaks anywhere in the turbo system. I have replaced the fuel filter, and after doing that the CEL went out, but symptoms still present (although limp mode is more rare now, but still present sometimes). A friend suggested replacing the N75 solenoid up near the firewall on the driver side (correct me if this is not the N75 or maybe that's not what it's called altogether). I haven't done this yet.
Will I be stuck with this new turbo 'attitude' (later spooling, lazy, and quiet whistle) or does anyone think it is possible that something is still wrong?
Any input at all is greatly appreciated!
Thanks for reading,
- Allan
0Silva1 is offline   Reply With Quote
Old September 21st, 2011, 00:58   #2
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Advice..take a very good look at the EGR cooler...If its OK, then the ASV/EGR valve warants a look.
2018 F150 3.5 ECO 3.55 10spd 20s 2tone 26mpg 2turb
2006.5 DE DSG, RC2, Sunroof, 200K miles, 61MPG best
2005.5 Jetta-5 SP LSD Spec S2 130K ELF506 10-30W OCI=20k ORIGINAL CAM RSB Diesel custom 2.5DP/3" SS Pkg 1 Auto-dim mirror auto-WW auto-climate 248tq=150HP RC2 lowered 312 brakes
Mach1 is offline   Reply With Quote
p0299 turbo underboost and smoke Mariusz257 VW MKIV-A4 TDIs (VE and PD) 9 March 9th, 2010 21:43
P0299 Turbo/super charger underboost unameiti'lltryit Ontario 5 May 3rd, 2009 16:35
Turbo problem no boost/underboost 04 Golf 1.9 BEW andy0310 TDI 101 19 December 5th, 2008 21:46
Turbo Underboost kayak01 TDI 101 9 June 8th, 2008 20:06
2.5 TDi V6 - New turbo = underboost, then overboost snapdragon TDI 101 1 May 1st, 2007 14:20
Page generated in 0.11832 seconds with 11 queries
[Output: 53.38 Kb. compressed to 49.40 Kb. by saving 3.98 Kb. (7.45%)]
