Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old August 4th, 2013, 20:09   #466
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
I have seen that on trucks but never on a VW, that line must have gotten damaged at some point to weaken it. I always when I take the lines off wrap them in clean cloth to protect them then into a clean zip lock bag until they are reinstalled..... Those lines are very tough so it takes some kind of injury or abrasion to it to make it fail.
More diesels than I can list
rotarykid is offline   Reply With Quote
Old August 4th, 2013, 21:02   #467
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
I imagine that can happen if the lines aren't loosened when the timing is adjusted since those you have to rotate the pump, more-so if the timing had to be adjusted far in either direction..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old August 4th, 2013, 22:45   #468
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
His is an ALH style pump where the sprocket is rotated to adjust timing.
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old August 5th, 2013, 06:45   #469
JFettig
JFettig's Avatar
I suppose its possible it was stressed from the previous owner as this was a line I got used.
JFettig is offline   Reply With Quote
Old August 5th, 2013, 08:30   #470
TDIJetta99
TDIJetta99's Avatar
That's right.. "Most" of the engine is like the AHU..
Old August 6th, 2013, 04:19   #471
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Actually, it's not just ALH style, it is an ALH 11 mm pump - same P/N, even - IIRC.
Originally Posted by Upton Sinclair
It is difficult to get a man to understand something, when his salary depends upon his not understanding it!
bhtooefr is offline   Reply With Quote
Old August 9th, 2013, 21:43   #472
JFettig
JFettig's Avatar
Looks like the Passat is being relieved from daily driver status.
Old August 22nd, 2013, 11:59   #473
bhodgkiss
that still amazing power from R520s and 11mm pump? 234whp?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old August 22nd, 2013, 13:12   #474
JFettig
JFettig's Avatar
There is more left in them Ben
Old August 27th, 2013, 06:55   #475
sardo_67
TDI(s): 2003 Jetta
Fuel Economy: 38mpg (driving like i stole it)
Originally Posted by JFettig View Post
Calculated RPM and torque
234whp, 373ft-lbs
Wasn't even hitting target boost, should be able to make 400ft-lbs
Almost smoke free
AHH with stock 11mm IP
PD Lift pump
Rosten H-beam rods
ASZ 18.5:1 PD pistons
R520 nozzles set to 230/340 bar
Stage 2 Colt cam
Ported head
GTB2056VL on a ported 1.6 TD manifold with adapter plate
2.5" exhaust, 2 resonators
SBC Stage 2 endurance clutch
Upgraded head bolts and main bolts
EVOMS FMIC
Custom boost piping
Custom intake.
4bar map
That should be everything.
that's a very nice power curve and something i'm going to shoot for. it must drive great on the road, what is your MPG like with this?
sardo_67 is offline   Reply With Quote
Old August 27th, 2013, 07:05   #476
JFettig
JFettig's Avatar
Fuel economy has pretty much stayed around 42-46mpg from stock turbo to this turbo.
Old September 8th, 2013, 12:06   #477
JFettig
JFettig's Avatar
EMP gauge line kept popping off and gauge was getting full of soot so it was a good time to clean it and clean everything up.
And for the hater(s), I installed my 5x.013 injectors and started tuning that in preparation for lots more air! Its roughly 50% more fuel than R520's!
Old September 11th, 2013, 16:49   #478
JFettig
JFettig's Avatar
Installed a wideband gauge today because knowledge is power!
Hooked it up to my data logger and logged a bunch of stuff.
I don't think IAT is calibrated correctly yet. I just pulled a bunch of numbers from VCDS
Old December 5th, 2013, 14:51   #479
RDC98tdi
RDC98tdi's Avatar
Fuel Economy: Best Tank: 49.5 MPG, Best 80mi trip: 59mpg
Any updates?
RDC98tdi is offline   Reply With Quote
Old December 5th, 2013, 15:06   #480
JFettig
JFettig's Avatar
I've been driving my JSW a lot. Blew #3 injector line and replaced it, running big injectors, clutch is slipping, turbo control sucks(reacts way too fast), new turbo setup will go in when I have time.
New clutch will come when it comes, its slightly detuned(360ft-lbs or so) to keep it from slipping. I probably won't spend much time on this car this winter.
Page generated in 0.19851 seconds with 10 queries
[Output: 129.33 Kb. compressed to 107.56 Kb. by saving 21.77 Kb. (16.83%)]
