Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old May 3rd, 2009, 05:31   #1
unameiti'lltryit
TDI(s): 2003 Golf
Default P0299 Turbo/super charger underboost
The service engine light came on when my wife was driving to Toronto and she said that she was not losing any power but the service engine light would go off and would come on again after a bit. On my code reader the code was P0299 Turbo/Super charger underboost. Any suggestions where I should start looking for the problem?
2003 Golf - 195,000 km
Was an automatic now a manual!!!
unameiti'lltryit is offline   Reply With Quote
Old May 3rd, 2009, 07:06   #2
hobbyshop
i think i recently got that code yesterday too!
on acceleration, it'd boost.. and then the turbo would cut out, and not much boost would be felt, so drop in power. after a restart, the boost would be back.
it's not as responsive as it used to be. sometimes it wouldn't boost at all, and would get lots of smoke on acceleration
hobbyshop is offline   Reply With Quote
Old May 3rd, 2009, 07:07   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
This code can result from an exhaust leak before the turbo. Typically, the only thing that can cause this is a leak on either of the egr pipes, or their associated gaskets.
There is also a chance that the vnt actuator is stuck, either by the vanes being frozen or the diaphragm being ripped, but check for exhaust leaks at the EGR pipes first.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old May 3rd, 2009, 07:14   #4
hobbyshop
i have blocked EGR... soo... vnt actuator is stuck? how do i unstick it. ha
Old May 3rd, 2009, 07:58   #5
Windex
Windex's Avatar
The best way to diagnose a stuck actuator or vanes is with a vacuum pump on the vacuum line from the N75 to the VNT actuator.
Use the pump to pull a vacuum on the actuator, and the actuator should draw in the rod attached to the turbo. The rod and actuator arm should move smoothly and evenly. If not, the vanes are likely sticking. If the rod doesn't move, and doesn't hold vacuum, then the diaphragm in the actuator is ripped, and needs to be replaced.
Old May 3rd, 2009, 16:35   #6
unameiti'lltryit
TDI(s): 2003 Golf
I will check the egr pipes and see if I can see anything for leaks. My wife was out with the car today and the service engine light didn't come on and she said the car was working good.
Page generated in 0.13962 seconds with 10 queries
[Output: 68.94 Kb. compressed to 59.80 Kb. by saving 9.14 Kb. (13.25%)]
