Old April 30th, 2008, 21:35   #1
kayak01
Fuel Economy: avg 38-40
Default Turbo Underboost
I took my 04 jetta wagon to a local mechanic for the check engine light. Code 16683 - turbo underboost. What does that mean? How do I fix it? and how do I keep it from happening again?
kayak01 is offline   Reply With Quote
Old May 1st, 2008, 01:02   #2
alphaseinor
Underboost is where the computer requests a certain amount of boost, and the turbo delivers an amount less than requested.
The '04+ have much better vacuum lines, so that's "probably" not it... my bet is on the VNT actuator, loose vacuum line, or an N75 valve.
Most PD engines won't clog the intake like the VE engines, but who knows... might as well pull the EGR valve and take a look.
alphaseinor is offline   Reply With Quote
Old May 1st, 2008, 07:05   #3
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
The vacuum lines might be better, but they are certainly not great... On my '04, the line from the N75 to the turbo wore through where the dealer routed it wrong (EGR recall). Check that line and go through your intercooler tubes. The one at the top (EGR connection) pops out very easily. There's a nice repair kit selling on the forums. I also added thicker orings in every connection from the turbo to the engine to prevent boost leaks.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old May 1st, 2008, 08:01   #4
kayak01
Thanks, I'll try all of that as soon as it stops snowing. Is it a bad idea to keep driving until she's fixed?
Old May 1st, 2008, 08:15   #5
HopefulFred
HopefulFred's Avatar
Fuel Economy: ~39 USMPG
It's probobly not too bad, but that means the turbo is trying to produce as much boost as it can, pretty much all the time. It's lot of work for it.
Novice VCDS user.
Proud owner and successful two-time user of AST timing belt tool kit.
HopefulFred is offline   Reply With Quote
Old May 1st, 2008, 09:37   #6
gforce1108
gforce1108's Avatar
If I understood my VAG-COM logs correctly, the N75 was trying to make boost all the time, but the turbo was not, since the actuator was not moving correctly. Mine slowly got worse as the line rubbed through more, eventually going into limp mode and throwing a code.
If there was a boost leak it would be much harder on the turbo.
Old June 5th, 2008, 15:12   #7
d2305
I have the same problem, but it's too hot out to work. I wish I were in Jackson Hole.
d2305 is offline   Reply With Quote
Old June 5th, 2008, 23:56   #8
TornadoRed
TornadoRed's Avatar
Too bad we never found out if kayak01 solved his problem.
'03 Golf with 803k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat fuel filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, Delvac1 Plus 2 other '03 TDIs
Become a TDI Club Contributor. http://forums.tdiclub.com/payments.php
Old June 6th, 2008, 09:32   #9
d2305
Driving up a 8000 ft. mountain will suck up the fuel. He's lucky to get 38mpg. I looked at all my vacuum lines and hoses, and they all look good. Guess I need to find a guru.
Old June 8th, 2008, 20:06   #10
ofhs93
Fuel Economy: 51/46/42
if all of the hoses and lines checked out ok try checking out your VNT actuator....the diaphrams in them have been known to fail (mine is borderline right now...does not hold perfect vacuum)....if it can't hold vacuum then it wont move the vanes in the turbo to create boost.
A recently overheard convesation involving a car enthusiast and one of our Guru's:
Luke S.: [on first seeing the "Ghostly" gray/blue 99.5] What a piece of junk!
TDIJetta99: She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself.
99.5 Black Jetta 5spd: 178k RC3 + PP520s =
03 Silver Jetta GLS 5spd: 175k MFA cluster, Hella E-Codes, rear fog, no power mods...for now
ofhs93 is offline   Reply With Quote
Page generated in 0.13593 seconds with 10 queries
[Output: 92.94 Kb. compressed to 78.43 Kb. by saving 14.51 Kb. (15.61%)]
