boomneverdies
my passat b5.5 Tdi(avf) had probleam in trans (01v) now can't forward (D) and revers (R) . but can move forward and revers in idel speed. now I'm chang new fuid + filter. and use vag com monitor at follow
1. code p730
2. all solenoid ohm ok
3. block 007 and block 5 if N215 0.648amp not forward and revers, and if N215 0.248amp Clutch action in idel speed (800rpm) but put accelerator (up 800rpm) N215 chang 0.648amp. not move
4. gear D2 (1m) OK (D,D4,D3 slip)
5. i'm check disconnect to Tcm (limp mode) R ok
please advice next procedure .....
1. code p730
