mat111
Hello,
Did an oil change today and the Mechanic told me that my "Intake Hose is starting to come off - common for intake tabs to snap off". There is oil leaking from around the Intake hose.
I inquired if the entire Intake hose needs to be replaced or just the Clamp. The Mechanic said he is not sure - because he did not clean the oil around hose to check if the hose is "ok/not damaged" or a worn out Clamp - which would require additional money to inspect, I was in a hurry.. so declined the inspection.
After coming home, I checked the Intake hose and I did see some oil spill and the Clamp is not firmly secured - but is not falling off either. I mostly drive on Highways and I am certain that my car is not losing any power ( at least I did not feel it yet ).
My question's are the following;
- How much does an Intake Hose cost?
- How much does a Clamp cost?
- I called the VW dealer in Hamilton,ON and they are quoting a price of $ CAD 300 for parts and labor.
- Is there a website I can order online in Canada/Ontario? I saw some based in USA, but USD conversion to CAD, and shipping costs are offsetting the savings compared to VW Dealer.
- Thank you for reading and would appreciate any helpful suggestions.
- Best Wishes,
Matt
- Best Wishes,
Matt
