kopeck
Morning,
My '01 Golf was making a chattering noise at idle. You could see the tensioner bouncing a bit and if I pushed on the shock the chatter went away.
After doing a little research it sounded like my alternator pulley was probably on it's way out. Before ordering parts I went out to check things out though. I pulled the belt off and I'll be if I can find anything wrong with anything. The alternator pulley works perfectly, I jammed the armature and it turns smoothly in one direction and locks in the other. The idler spins nice and smooth as does the idler on the tensioner.
I put it all back together and for what ever reason chattering seemed to be better. It's not completely gone but considerably less noticeable.
So...that leaves the shock, right? I can't think of any other thing it could be. Just running it past you folks before I order parts.
Thanks,
K
Thanks,
K
