I have an 02 Jetta tdi alh engine. When I unlock the doors using the unlock button on the driver door the trunk pops open. I’ve already replaced the latch and repaired the broken wires. Anyone have any ideas on what it could be.
You repaired wires in the accordion if the front door, and within the door?
Seems like it's a couple wires touching inside the door accordion or the body side.
Often it's the wires in the accordion to the body as they continuously bend back and forth rubbing against each other. Eventually they wear through and the conductors make contact forcing one to act with the other.
My question is do the doors unlock when you pull the trunk release switch?.?.
