Recently I was drinving my 2005 Passat tdi (270,000 km) and I hit a bump on the drivers side my traction control light started flashing and then it just stayed on. When I shut the car off and turn it on again the light goes away until I spin the tires on ice(we still have icy road here in Canada) then the light comes back on (and stays on) and the traction control does not function. I also did have a weird situation when I was on ice then I hit pavement and the traction control started slowing me down out of the blue- it was a little unnerving because it should not have kicked in at that time. Also I do not have a VCDS, I do have a normal code reader.
Questions:
If I hit the ESP button on the dash it will shut this system off?
This system is somehow linked to the ABS sensor? Is it likely the sensor is damaged or maybe a wire is damaged?
Is it worth it to try to fix this or should I just forget about it?
Cheers,
PingPong
Questions:
Cheers,
PingPong
