Yardstick
I probably just need to get friendly with some of my local Vag-Com ownin' TDI'ers (I have one one the way), but hopefully somebody can give me some direction here... I've already done a LOT of searching, but it seems like there are so many potential issues that I'm hoping someone can help me narrow this down (or maybe give ideas for other things to check). I've had my car since Friday and I really like it. It did come with some issues (thus my getting it for ~50% of what these things are going for right now ). When I got it, the ABS light was on and the BRAKE light was flashing. Otherwise, everything worked great. The person I got it from said a dealer service center diagnosed a bad ABS pump. While driving the car around Saturday, the glow plug light started flashing. I searched and tested and sure enough, no brake lights.
I replaced the brake switch this morning with a new purple one and now the ABS light and BRAKE light are intermittent and I get more beeping than before. Before it would just beep when started and then be quiet for the rest of the drive. I'm starting to wonder if it might just have a bad ground since that seems to cause similar symptoms.
If I go checking grounds, I've been reading I have to remove the battery. If I do that, it sounds like I might disable the stereo. How can I avoid that? I don't have the radio code (Monsoon). Can I get the radio code through Vag-Com?
The brake fluid level is about halfway between the Max and Min line. Could that be it? I would expect a beeping when it's at the Min line, but not half-way between. I think I need to change the fluid anyway. Any suggestions where to get it? Is standard DOT 4 from the local auto parts store okay?
Could it be a wheel speed sensor? Could one of those be activated if the tires are slightly different pressures from side to side?
I have a Bentley service manual on the way too, so hopefully I'll be able to answer more questions than I'm asking now.
