treeeman00
Ive searched and searched for answers but have come up short. My right rear turn signal is not working. Everything works on both sides except for the rear turn signal. Ive swapped the left side board to the right but still doesnt work. Ive replaced the turn signal assembly on the column with a known working one and replaced the flasher relay. Relay is working and lights up. Front turn signals work. Ive pulled back the trunk carpet and checked the wiring and cleaned the grounds back there. I am getting voltage but only 3 volts to the circuit board for the turn signal. Was getting 7 at one time and still wasnt working. When i first started out the dash indicator for the right was very dim. Now its bright. All the bulbs are good. Even with the good bulbs, the turn signal indicator on the dash is flashing fast like I have a bulb burnt out. Any help is greatky appreciated. Need to know where to check from here. And the jetta is a 02. Thanks
