highmileage
- Joined
- Sep 17, 2013
- Location
- new jersey
- TDI
- 2005 passat bhw tdi (presently), 2001 jetta alh tdi (previously), 1998 jetta ahu tdi (previously)
When a DTC is thrown, it get stored so it can be read by an instrument for the appropriate fix. My question is - after the fix, does the computer recognize this and erase the code automatically or does it still have to be erased manually by the instrument? Also if the code to be repaired, is repaired, but the code is still in the system (if it is) does the computer still recognize it as a problem or not as no problem any longer exists (since the repair has been done)? Thanks in advance.
