So, the other fun thing I was able to do on the dyno yesterday, was hook up a cylinder pressure sensor. This is the same one that CharlieT was using above.
Data sampled at 50kHz - I'm working on plotting it vs crank angle but not quite there yet.
First image of the data is really just an overview of the whole dyno run from 1000 to 4000 RPM. Since the RPM varies quite a bit with each combustion cycle (see 2nd picture) when you plot against RPM, you get "noisy" graphs, but it's still useful to show peak cylinder pressure vs RPM in relation to power and torque I think.
Looks like peak cylinder pressure is ~235bar at ~3000 RPM and a secondary peak at ~1750 RPM under 200bar.
Here's 1750 RPM zoomed in (now plotted vs time instead of RPM)
X axis is time in seconds
Y axis is kW, Nm, Bar and RPM/10
You can see the RPM variation with each compression/power cycle in phase with the cylinder pressure sensor which is pretty cool.
Zoomed in to one combustion cycle. I'm guessing that combustion starts at ~85 Bar where the sharp rise in pressure is?
Here's another zoomed in one at ~3000 RPM - Scale is different on the Cylinder Pressure (right/red Y axis). Combustion starting at ~120 Bar?
Cool pictures at this point really - can't do too much with it without knowing actual crankshaft position, injection timing, etc, but it's a start
More to come as I get bits of time to work on it (and if anyone has a cable from a crank sensor).
