I try to post what I went through to give the average mechanic would go through potentially. So thanks for your concerns on how long it took me, I like to take my time and make sure everything is right considering this is my first turbo install.
Chiro, let me put it this way...it is a plug and play turbo. We just happened to run into problems that were not supposed to happen, IE actuator nipple being broken off and wrong threaded banjo bolt. After getting a tune revision I would 100% say I would buy this turbo again. Not looking for a drag car or a street racer and I realized the limits of this motor long before i made my decision with this turbo. For the $$ it cost to get 50-75 more horse id rather get a VR6 and turbo that and have something scary fast. (puts on flame suit
A5, I know they are severly limited without new injectors. We had already talked a while ago about doing the 783 nozzles on my bew bodies but i know others obviously wouldnt know this information.
Ryan, Im not trying to bash your product in anyway shape or form. And if it came off that way i sincerely apologize. I had several quotes for turbo r&r from different mechanics and they all quoted 9 hours labor. So with that being said it would have been done in about 7 if we didnt run into the problems we did.
Losha, we saw no need to remove the intake manifold since it was a clear shot from the bottom and the oil return line needed to have new seals put on anyway. We removed the axle just to give us more room. Its all of 8 bolts if i remember correctly and made working on everything much easier from the bottom. I could have sat indian style on the ground with my head in the opening if i wanted to. You have your ways of doing it and I have mine
Finally onto updates....
Emailed Mark Malone after running logs and everything checked out so he bumped the boost pressure.
NOW IM IMPRESSED!! I dont know how many times i needed to state that i was not making any final decisions until everything was at 100% capacity. I have full faith in the numbers you posted that your clients have received with this tune ryan as well as full faith in Mark Malone for tuning the car to its full potential.
Still need to run a few more logs to get the final boost pressures set and for some reason im still getting a MIL for the smart actuator, Mark said he did the exact same coding for another person running a wastegated turbo on a brm so he is going to tweak it to see if we can get it to go away.
