Zheking
LED brake lights and flashing glow plug light - adding resistance
Put some led brake lights in and got the flashing glow plug light. Rather than installing resistance at the back by the lights or dummy light, I ordered a new brake pedal switch and I'm just going to install an internal resistor in it. Problem is, after looking through the FSM I just downloaded (these are much much more difficult to navigate through than the nissan ones i'm used to), I can't seem to find which pins / wires are for what. I found voltage specifications, max resistance ohms, and a few things like that.
Does anyone who's a little more well versed in the FSM know which pins are what?which ones the resistor will need to go between that's monitoring the brake lights? labeled 1,2,3,4 on the outside, and obviously on the back side they're going to be opposite.
