POWERSTROKE
I have (2) 2002 golfs. I’ve cleaned behind those front liners every year. I’ve also had one fender replaced on each car about 7 or so years ago under the vw replacement plan. I now have a fender on each car that is rusting through at the bottom again. Being that these cars are close to 2 decades old, I am almost totally against spending $3k on each car to do this the right way. The reality is that all four fenders rockers would have to be done to really be able to get it perfect. I know the rocker is an “endcap” right behind the fender liner that is replaceable. My question is how structural is that part? I bet more than half the a4s around are driving with rust in that area (I look at everyone I run across). I pressed the lower portion of my fender with my thumb yesterday and put a small hole through it. Definitely a horrible design. Not much you can do other than clean stuff out as it just is always wet and moist in there. So for those of you that have this, what have you done. I’ve already done this repair once in each car and kind of feel frustrated with this at this point.
