KrashDH
Just another word of caution for glass lenses. If you plan on going aftermarket glass, ensure they are NOT the B grade lenses (only if you are planning on retrofitting projectors into the headlight). Those usually have imperfections (think bubbles or wavy to the eye a bit). The refraction of light is different between glass and polycarbonate. If you're using B grade lenses with projectors your light output/cutoff could potentially be distorted.The answer to this is: Absolutely! When I got my Ebay knock off E-codes, I dismantled them before they ever went on my Jetta_Wagon, and installed glass lenses. I just used a heat gun to gently warm the housings to separate the lenses from the backs. For those worried about breaking glass lenses, My '80 Scirocco, and '90 Corrado had factory glass lenses, and I never broke one while driving. The LaminX on the glass Jetta lenses is now cloudy after 6+ years... (the Ebay Ecodes have very poor copies of Ecode reflector optics based on the Ecodes I had on the Scirocco and Corrado). I'm looking for upgrades as well, that's why I was reading this thread.
Incidentally, one of the mounting pegs was broken when I received my knock off Ecodes back in 2012, so don't blame the border crossing for breaking the Midwest upgrades. I think it's a shipping thing with these lights in general.
For all the projector retrofits I've done on my vehicles, I've used poly to avoid this. Yes, the ebay lenses are cheap. It's not necessarily that the lens material is inferior, it's the fact that the clearcoat on the ebay lens is where the companies cut corners (among some other things). It chips and then peels wicked easy.
Right out of the box I normally rough the lenses up to 1500 grit and then hit them w/ 4-5 coats of car clear coat. They will dang near last forever that way. As well, looking at the front of my bumper and hood (at least around here) that area gets peppered with rocks. There's always the chance the glass could crack, something poly would resist. @where2, sounds like you have had good luck with glass over the years not cracking which is great!
