hi all, i changed front suspension parts on this and when i started it the steering light was showing in the dash and it is hard to turn steering thus electric assistance not working,
I pluged in Vag and it came up with fault 00573
00573 - Steering Torque Sensor (G269)
008 - Implausible Signal
i checked all conections and all ok, cant understand why it has this fault when none of the steering wires were touched when putting in shocks
i also carried out the following check -
** To Checking Steering Torque Sensor (G269)**
Prerequisites:
* Ignition ON
* Engine ON (Idle)
* System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Group 001
[Go!]
Field 2: Steering Torque Sensor (G269)
Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change.
If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors.
If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty.
Group 004
[Go!]
Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON"
[Done, Go Back]
[Close Controller, Go Back - 06]
torque values didnt change for me so it would point to sensor or power supply, power supply ok so it points to sensor but how could the sensor have failed while just changing the 2 shocks,
can anyone shed some info on this and a possiable cure because there must be another reason for it to have stopped working ?
regards
marty
Prerequisites:
* Ignition ON
* Engine ON (Idle)
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Group 001
[Go!]
Group 004
[Go!]
[Done, Go Back]
regards
marty
