Old April 26th, 2014, 12:27   #1
Justinw303
Default Anyone else heard this sound at high (100+ mph) speeds?
So today I having a little fun on my favorite stretch of interstate around here (easiest place to get some speed going) and took the Passat over 100 mph for the first time.
As I reached that point, and until I had decelerated enough, there was a flapping/knocking sound coming from the engine compartment. Sounded like plastic was involved, but I definitely wasn't sure. So I tried it again. Reached 100 and heard the same sound.
My hypothesis was the engine cover was flapping in the high air speeds under the hood, so I checked things out when I got home. Sure enough, the engine cover felt loose enough on one of the corners to do some flapping at high enough speeds.
So the point of this post is, anyone else experienced this? Did you confirm it was the cover and not something else? Anyone figured out a way to secure the cover better?
Justinw303 is offline   Reply With Quote
Old April 26th, 2014, 15:09   #2
Driver_found
No flapping here. The OEM securing points normally are very good unless someone took a shortcut and didn't secure things properly.
Driver_found is offline   Reply With Quote
Old April 26th, 2014, 16:16   #3
Good Ol' Boy
VeeDubTDI's Avatar
Was the cover pressed all the way down onto the mounting points? There is a very noticeable indentation when they're all the way on.
Old April 26th, 2014, 19:21   #4
jrm
Fuel Economy: 42/52
nope, quiet as a mouse when I broke mine in with several 110MPH runs up a 4% hill
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old April 27th, 2014, 06:10   #5
50pascals
Never hear anything like that from up front.
I don'r know how the engine cover could get loose on it's own. You have to yank that thing hard to get it to pop off.
50pascals is offline   Reply With Quote
Old April 27th, 2014, 07:42   #6
tdiatlast
OP says "engine cover", but I thought he was talking about the hood liner...My 2012 liner did shrink, pulled loose at the back, but I never heard it make any noise...never drove 100+!
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is online now   Reply With Quote
Old April 27th, 2014, 16:58   #7
nord
Usually the noise is a siren accompanied by a light show. Then a racing award.
nord is offline   Reply With Quote
Old April 29th, 2014, 17:16   #8
BMKruse
TDI(s): 2012 JSW
LMAO... I have gotten a few racing awards... One with a special set of bracelets. They took them back once they couldn't prove I deserved them.
BMKruse is offline   Reply With Quote
Old April 29th, 2014, 18:08   #9
mrmoto35
I have hit the rev limiter several times and do 102-105 sort of often on the quiet stretches...no noise here.
mrmoto35 is offline   Reply With Quote
Old April 29th, 2014, 18:18   #10
passsattdi
passsattdi's Avatar
Remove it and see if it happens when you have some more fun. Will answer the question... I never heard it, but my cover is not loose.
passsattdi is offline   Reply With Quote
Old April 29th, 2014, 18:53   #11
passatv6af
TDI(s): B7 6MT
Maybe your grille was loose?
passatv6af is offline   Reply With Quote
Old April 29th, 2014, 19:00   #12
MichaelB
Fuel Economy: very good
Never drove that fast to have that experience........nor do I care to. You sir are a danger to me and my wife when we are out driving. Kids stuff and it could get somebody killed if it's just you that's fine with me, but there are other people out there on that highway. If you want to do that stuff take your car to the track. Nuff said
MichaelB is offline   Reply With Quote
Old April 30th, 2014, 01:44   #13
Deepwater6
Deepwater6's Avatar
Fuel Economy: average 38-40 MPG
I have to chuckle each time I see the OP. I bet I'd hear things too over 100 mph......LOL!
Deepwater6 is offline   Reply With Quote
Old April 30th, 2014, 03:20   #14
tdiatlast
Where's the OP? ...hope he didn't get hauled off after his follow-up test drive...
Old April 30th, 2014, 13:58   #15
Justinw303
Haha sorry, I'm back. Got busy and briefly forgot about the thread.
Anyways, when I originally looked under the hood, I grabbed parts of the engine cover and tried to see what moved. The corner on the front passenger side of the engine I could move up and down an inch or so. It's not as if it's completely loose or floppy, it just has some definite give to it. Something that could maybe make noise at higher speeds. Just not sure.
I guess I'll take a look under there again and see if there's any other possible culprits, and maybe take off the engine cover and test it that way. Any chance it could have been a something more sinister, like an engine-related failure? No lights popped up on the dash, car has driven normally since then.
The next chance I'll have to stretch her legs will be thursday night, making an overnight roadtrip so there will definitely be an opportunity to safely make a test run.
Weird noise on acceleration (low speeds 20-40 mph) spangenberg VW MKV-A5 Golf/Jettas 1 September 2nd, 2010 12:47
hard to describe noise can be heard around 30-25 mph robdubya VW MKIV-A4 TDIs (VE and PD) 1 June 21st, 2009 20:58
100 mph to 120 mph hkbladelawhk TDI 101 42 September 29th, 2006 04:30
EUREKA I've got it !! 100 MPG , 100 MPH TDI 1.2L koshkadrook TDI 101 8 June 1st, 2004 06:16
Grinding noise when breaking at speeds of less than 15 mph garnet VW MKIV-A4 TDIs (VE and PD) 2 February 8th, 2003 17:54
Page generated in 0.15477 seconds with 11 queries
[Output: 124.28 Kb. compressed to 103.70 Kb. by saving 20.58 Kb. (16.56%)]
