Old August 18th, 2011, 10:08   #1
Bud44
Bud44's Avatar
TDI(s): 03 Jetta TDI
Talking Post your 'Dynolicious', 'Bosch Light Em Up Dyno' Results Here !!!!
Post your Dyno results here.
Apps for iPhone
Dynolicious
(Paid App) $12.99 - Quarter mile, horsepower, 0-60 time, etc.
Bosch Light 'Em Up Dyno
(Paid App) $4.99 - Quarter mile, horsepower, 0-60 time
(Free Version) Only measures 0-60 time
Bud44 is offline   Reply With Quote
Old August 18th, 2011, 10:13   #2
85_305
Banned
Kinda interested.. even though the accuracy of said instruments is of debate to me.
85_305 is offline   Reply With Quote
Old August 18th, 2011, 15:05   #3
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
I want to see the OP's dyno results first!
Seriously though, for Android users there is an app called "Dynomaster" that is pretty useful.
Also, VCDS can be used to log data from which you can find 0-60, torque, etc.
manual_tranny is offline   Reply With Quote
Old August 18th, 2011, 16:11   #4
chapelhill
I have not see the Dynomaster one for Android, but I have the one called Torque app for Android which I highly recommend, but limited sensor access on VW/Audi as it only uses OBDII protocol. It maybe my cheap ELM clone wireless adaptor.
Regards
Chapelhill
Seat Ibiza 03 PD130. FMIC,2260Vk Turbo, Miltek turbo back exhaust.(working on someMORE!)
Mercedes E280CDI for the wife!
chapelhill is offline   Reply With Quote
Old August 18th, 2011, 16:57   #5
Bud44
Bud44's Avatar
I just tested my car.
Dynolicious
98 Jetta TDI
VEG-216, Chipped, muffler delete
3000 Lbs & 15% drivetrain loss
121 HP (2nd gear pull)
http://youkits.freeforums.org/
Old August 18th, 2011, 17:18   #6
manual_tranny
Deleted first question, saw answer in your signature.
How many PSI is your "chip"?
Old August 18th, 2011, 18:25   #7
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Will you accept similar accelerometer guessed peak power numbers from G-Tech devices on this thread?
Similar concept to the phone based programs: input the guessed weight, level the device, accelerate. Then it's just math: F=M*A.
And how did you determine the drive line losses? Not that it matters as wheel HP is all that counts. If you want a bigger HP number for boasting purposes use 20% loss and calculate fudged power at the top of the pistons rather than half-fudged at the flywheel.
Svante Arrhenius 1896
Old August 18th, 2011, 18:44   #8
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Any accelerometer-based dyno app is not worth the results it gives without inputting things like accurate weight from certified scales with the EXACT payload at the time of testing, tire size, gear/final drive ratios and coast-down tests, the latter preferably on as near perfectly level stretch of road as possible and averaging runs at least once each in both opposing directions to factor out tail/headwinds and grade differences.
Putting a guesstimate weight can throw off the HP results significantly. Drivetrain loss factors are dubious as well.
Old August 18th, 2011, 19:02   #9
manual_tranny
Yup! But if they are accurate in identical repeated tests, they could provide a way to measure changes in performance.
Even professional dynos are "inaccurate" compared to other professional dynos...
Old August 21st, 2011, 14:47   #10
Bud44
Bud44's Avatar
Around 19 psi
Kill Stories... post em up! tdipower4me TDI Motorsports 137 February 3rd, 2016 18:23
First ever DYNO results,not right? DYNO PLOT pic gor131-x TDI Power Enhancements 19 December 4th, 2008 04:33
FS:4 BOSCH GLOW PLUGS/1.9 L/TDI BEST OFFER GETS EM wHiTeOuTs Private TDI Items for Sale/Wanted 1 November 24th, 2005 16:03
Injectors-Post here to tell us where to get them and what price you got on em hallopt45 Private TDI Items for Sale/Wanted 2 July 20th, 2001 14:17
Chip/Box/Epsilonian/K&N dyno run -- Read -em and weep ;)! BIGJOHNO TDI Power Enhancements 1 May 11th, 2001 14:49
Page generated in 0.14849 seconds with 11 queries
[Output: 102.63 Kb. compressed to 87.32 Kb. by saving 15.31 Kb. (14.92%)]
