Old July 7th, 2011, 09:35   #1
Asmerrill
Default Looking to buy an outdoor car cover
My car sits out in the elements for 24 hours when I'm at work. During the summer, the monsoons blow through kicking up dust and also when we take off, the rotor wash blows dirt everywhere. Any suggestions as which one I should get?
Asmerrill is offline   Reply With Quote
Old July 8th, 2011, 19:16   #2
Fordcougar
Fuel Economy: muy bueno
With that much dust blowing around combined with the rotor wash, I'd be worried about it getting trapped between the cover and the car and really causing damage.
2011 JSW DSG Candy White... Stock for now. Central Florida
Fordcougar is offline   Reply With Quote
Old July 8th, 2011, 21:42   #3
Lightflyer1
Lightflyer1's Avatar
The one that comes with a garage. The covers may be good for water, sun and bird droppings, but dirt and/or sand and a cover won't be good. I think it would be better to have the sand hit the car than be ground back and forth under the cover like sand paper. Park farther away from the chopper so the rotor wash isn't so bad.
Old July 9th, 2011, 06:44   #4
rte2MA
I went through this a year ago when I was trying to figure out how to protect my new 2010 which doesn't have a garage. I eventually decided against a car cover. From what I read it sounds like it's too easy to scratch the finish unless the car is pristine clean before adding the cover. Plus, if the cover is on for any length of time in our climate you can end up with condensation.
So I'm just doing the best I can with lots of washing/waxing & TLC. And I do have a makeshift contingency plan if it looks like we're going to get a hail storm (happily nothing I've had to try out yet). Your conditions do sound challenging though. If I were in your shoes I might go for a light short-term cover with the softest lining available.
2011 Golf TDI 6M, 2dr, United Gray, cold weather pckg.
2010 Golf TDI 6M, swapped out for the 2011 at 26k after double HPFP failures.
2001 Jetta TDI 5M given to a friend, 250k and still going.
rte2MA is offline   Reply With Quote
Old July 9th, 2011, 12:09   #5
Victor-Whiskey
I had a similar situation once. I used a lightweight nylon cover with strategically placed nd magnets to hold it still, and tied under the car securely. Was on for 3 mos while I was TDY. Worked great.
2015 Jetta TDI
2015 Subaru Forester
2012 Porsche Cayenne
Victor-Whiskey is offline   Reply With Quote
Old July 11th, 2011, 10:15   #6
Lightflyer1
But was it in AZ in the desert getting blasted by wind and dirt/sand and rotor wash? The only green I see around that area is a golf course. Any where else that wasn't a desert like environment I would say a cover would be fine.
Outdoor Thermometer john173 TDI 101 0 November 25th, 2007 10:42
Where to buy a good CAR COVER?? Schwrtz27 TDI 101 7 February 15th, 2006 18:27
outdoor storage sooner Ontario 1 November 21st, 2005 16:05
FS: NB car cover (VW factory cover) AndiS Private TDI Items for Sale/Wanted 0 December 2nd, 2003 11:40
FYI: Adding An Indoor/Outdoor Digital Thermometer To Your Car For $10 Ric Woodruff Upgrades (non TDI Engine related) 3 September 10th, 2001 07:09
Page generated in 0.17117 seconds with 11 queries
[Output: 74.20 Kb. compressed to 64.72 Kb. by saving 9.48 Kb. (12.77%)]
