Old January 12th, 2009, 07:31   #1
lockwood
Default 2004 TDI starts better in cold weather but in warm weather?
I have been getting glow plug heater 3 codes for a while I replace the glow plugs (autozone bosh plugs) I am sure they are not the right one. Car still gets the code. It starts on the slow side not like on my ALH jetta engine where you just bump the key. Now this morning it was 20 degrees out and my wife barley bumped the key and started right up.. This maybe a waisted post, I have a feeling it is in the values. For a while I was thinking it could be my battery which is the one that came in the car, but after this morning? I don't think so. still need to get that thing load tested..
lockwood is offline   Reply With Quote
Old January 12th, 2009, 16:45   #2
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Glow plugs
Yes, you put in wrong glow plugs! Your 04 PD TDI came with ceramic plugs. To change to steel plugs the ECU has to be flashed. This has been discussed throughly. Do a SEARCH on ceramic vs steel glow plugs!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old January 12th, 2009, 17:36   #3
puter
Fuel Economy: 57 mpg
man, you've become the Search **** starwars.
puter is offline   Reply With Quote
Page generated in 0.14349 seconds with 10 queries
[Output: 55.29 Kb. compressed to 50.00 Kb. by saving 5.29 Kb. (9.57%)]
