Old June 15th, 2019, 16:29   #1
ryanmonahan
Angry 2015 Passat TDI 2.0 DSG Overheat and died
For the last year my Passat has been losing about a cup of coolant each month. Dealer couldnít find any leaks.
Today I topped it up and drove about 40km on Hwy and suddenly temp went way high. Pulled over and took a look coolant level was fine. I was right at an exit so I started back up to get off hwy.
Almost immediately it started beeping and lost power. Had to pull over as it stalled out. Got it towed to dealership.
When I first looked a bit of white smoke was drifting out from under the engine cowl. couldnt see any other obvious signs of trouble.
Iím at 95,000km
In Canada.
Any ideas? Hopefully warranty still good.
ryanmonahan is offline   Reply With Quote
Old June 15th, 2019, 20:33   #2
Tom in PT
Fuel Economy: 30-48 mpg in '05 ; up to 53 in '13
I'm pretty sure the 2015 Passat came with a 5 year, 60,000 mile (= 96,560 km) powertrain warranty, whichever occurs first. You should confirm that.
Unless you have done something that could give rise to a denial of warranty (like install an aftermarket performance chip , or fail to maintain it per the maintenance schedule), at first glance the warranty should cover repair or replacement of your overheated engine. If your "95,000" miles is approximate you need to be more precise as you are very close to the mileage limit.
Tom in PT is offline   Reply With Quote
Old June 16th, 2019, 09:38   #3
thundershorts
sounds like the water pump impeller spun on shaft.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old June 18th, 2019, 07:53   #4
740GLE
Def thinking water pump as well.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old June 19th, 2019, 18:08   #5
ryanmonahan
Thanks folks... itís been sitting at the dealer now for 3 days and I havenít heard a thing. Iíll go in there tomorrow morning to see whatís up. It should be warranty. The only issue I can see is that I canít find my last oil change receipt and it wasnít dealer... they charge $170.
Old June 20th, 2019, 02:53   #6
Matt927
Matt927's Avatar
TDI(s): several
They can not deny you a warranty claim because of that.
Matt927 is offline   Reply With Quote
Old June 20th, 2019, 08:55   #7
740GLE
they can most certainly try
Old June 20th, 2019, 09:57   #8
ryanmonahan
So I stopped at the dealer just now. Didn’t see my car but the service rep
Had some pics. Tensioner on the timing belt seized and belt burnt up. That was the problem that led to overheating. Report is sent in to VW Canada for them to decide if they just do timing job or if they rebuild engine to avoid hassles later if related damage happened when belt broke. Rep says dealer recommends engine rebuild but ultimate call on warranty issues is up VW Canada cause they foot the bill. Anyone have any insight on this?
Old June 20th, 2019, 10:06   #9
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You will want a new engine. A "rebuild" at the dealer level will result in something you will probably not like. This sounds like a really strange thing, but I guess it could happen. I do not see how a seized timing belt tensioner could cause the engine to overheat. All I could see happening is it rubbing through the belt to a point it failed, then the car just stops, but it would have been at normal temps right up until then.
Now what seems MUCH more plausible, is that the WATER PUMP seized, and since it runs off the smooth side of the timing belt on that engine, it would not have ripped the teeth right off the belt. And THAT would certainly have caused the engine to continue to run, so long as the belt was not yet rubbed through, and get hotter and hotter until either the belt broke and tooefed the engine, or the temp got too hot and tooefed the engine.
Either way, engine is likely beyond reasonable repair. Besides, the cost of the long block will be less than the cost of all the parts and labor to try and fix one. Current list price for a CVCA long bock, 04L-100-033-DX is about 4 grand. That is CHEAP. Valve over to oil pan.
oilhammer
www.cardocautomotive.com
Old June 20th, 2019, 10:57   #10
ryanmonahan
Awesome thanks for your advice. I will be talking to them about this.
Old June 20th, 2019, 11:43   #11
thundershorts
Wonder if the design of running the wp off the smooth side of belt was to not break the timing belt in the event that happened?
Old June 20th, 2019, 11:56   #12
oilhammer
oilhammer's Avatar
Possibly, and we see how bad the 2015's variable displacement water pumps already are, LOL.
oilhammer
Old June 21st, 2019, 04:51   #13
thundershorts
When VW replaces the variable wp under warranty is it replaced with a non variable or is that possible?
Old June 21st, 2019, 05:07   #14
oilhammer
oilhammer's Avatar
I have been told the new replacement ones do not have the collar on them, but the electrical plug is still there. Since there is no feedback for the position, I guess the ECU doesn't care. You'd think there would be some coolant temp monitoring, and if it was flowing 100% all the time it might cause some coolant under temp problems, but I guess that situation doesn't happen or the engines just run so hot anyway that the use of the system is worthless anyway unless you live in Antarctica.
The later VR6s in the T'regs have variable pumps too, but they are vacuum controlled (duty cycled solenoid on the front of the engine) but I have never seen any problems with their collars coming loose.
I suppose the next step will be an electric pump, like the later Prius uses, that costs $700 and randomly without warning dies and tooefs the whole engine just the same.
oilhammer
Old June 24th, 2019, 09:35   #15
740GLE
This. It's the chicken or the egg, and it seems VW never thinks it's the egg to blame.
Hopefully this water pump of the '15 isn't the balanced shaft of the B5 or the cam wear of the PD.
2012-2015 DSG Passat TDI. colezy9 VW Passat Family (NMS and B7) TDIs (2012+) 11 April 10th, 2018 12:19
2015 Passat w /DSG jketron TDI Power Enhancements 5 November 22nd, 2014 08:29
2012 Passat DSG - engine died this weekend shortly after start up Papachristou VW Passat Family (NMS and B7) TDIs (2012+) 38 June 1st, 2014 09:45
New 2015 Euro-Passat (B8) heralds arrival of new 2.0L twin-turbo TDI & 10-speed DSG JimNap VW Passat Family (NMS and B7) TDIs (2012+) 24 May 20th, 2014 10:26
Overheat and die vs died while over heating runes52 VW MKIII-A3/B4 TDIs 5 June 30th, 2013 16:07
© 1996 - 2020, All Rights Reserved
Page generated in 0.16707 seconds with 11 queries
[Output: 128.28 Kb. compressed to 107.16 Kb. by saving 21.11 Kb. (16.46%)]
