Old May 28th, 2019, 10:54   #1
GoontherTheGolf
Fuel Economy: 30 miles/gallon with a failing tranny
Default Anyone have some low budget mod ideas for a 03 MkIV Golf TDI
Pretty much as the title says
Iím tired of being in a car that doesnít pass 100hp, so I figured this would be the best place to see what ideas people have. I just put on an EGR delete and now Iím wondering what else can I do to this thing?
GoontherTheGolf is offline   Reply With Quote
Old May 28th, 2019, 11:00   #2
Nero Morg
Nero Morg's Avatar
How cheap is cheap? Also, is yours auto or manual? You could try the evry mod, but that's a limited mod and can lead to destroyed parts if done wrong.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old May 28th, 2019, 11:11   #3
GoontherTheGolf
Sorry, should’ve added a bit more info. It’s an automatic and cheap for me is between $100-$200. I’m a bit new to this and I wanna know what I can do.
Old May 28th, 2019, 11:12   #4
Owain@malonetuning
Slap a set of nozzles in and call it good, any of the name brand stuff from Europe will work fine, avoid no name ebay/amazon nozzles and make sure to at least do basic pop testing. I'd steer clear of tuning boxes or unknown flashes, there's cheap tunes floating around online but they could cause more harm than good. If you plan to play around with it and tune it yourself/cheaply, I'd start by picking up a VCDS cable to make sure you can diagnose things to make sure it remains reliable, or at least a boost gauge. VNT15 should be around 18psi at sea level, with spikes no more than low 20s.
since it's an automatic your injection pump flows more and you have smaller nozzles to compensate. A set of DLC520s would be sufficient.
Owain@malonetuning is offline   Reply With Quote
Old May 28th, 2019, 12:05   #5
Mongler98
go get a set of soft summer tires 350 or lower rating, and go autocross with it.
Nozzles, tune, and a clutch if you want more power but cant afford head work or a $$$ turbo
autocross is NOT about fast cars, its about good drivers, good meaning skills.
Old May 28th, 2019, 12:18   #6
GoontherTheGolf
Thanks for these couple ideas and one more question. This is more of a long term thing but what would be a next step turbo instead of the stock one?
Old May 28th, 2019, 13:29   #7
flee
flee's Avatar
Fuel Economy: 40-ish
Tune after the nozzles.
I have The DLC520's with a tune and an auto. You'll like it.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old May 28th, 2019, 13:38   #8
Mongler98
swap the n75 bits for the ALH parts, and get a vtn 17/22 hybrid.
you WILL need a clutch if you do anything more than just a light tune
Sachs stage 2 endurance clutch and 14lbs flywheel kit, 502's or 764's, 17/22 turbo with manifold, EGT gauge, tune, PD150 intake, colt cam, and 11mm IP with a few supporting upgrades is about as beefy as you can go with out custom fab. take this combo as your base line for MAX modding with little issue.
Old May 28th, 2019, 15:54   #9
flee
flee's Avatar
Sheesh Mongler, read. It's an 03 with an auto.
Old May 28th, 2019, 16:07   #10
Mongler98
well then your half way there with the IP and the vtn!
opps
facepalm
Old June 7th, 2019, 12:10   #11
Votblindub
Votblindub's Avatar
Look at my white car(in signature), it's around 100hp or so. Shoot me a PM if you have any questions. I've been dailying it and no issues so far.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old June 7th, 2019, 12:32   #12
crazyrunner33
crazyrunner33's Avatar
If you're going to keep the car for a long period and plan on upgrading, then this thread is something you'll want to tackle after a certain point.
http://forums.tdiclub.com/showthread...da+auto+wabbit
I'm not sure if he still sells it or not, but Fran has the kit(no clutch) listed for 975:
http://forums.tdiclub.com/showthread.php?t=434593
Some of the vendors on the site were quoting around 900 for labor.
'06 Jetta DSG: Lifted, a few go not as slow goodies
'14 Ram 2500 Cummins
crazyrunner33 is offline   Reply With Quote
Old June 7th, 2019, 15:18   #13
Mongler98
stock is 90HP, 100? what you do, tighten the turbos waste gate? lol
Old June 7th, 2019, 15:23   #14
Lightflyer1
Lightflyer1's Avatar
Unless you do your own work $100 to $200 won't actually get you anything. You need a bigger budget or leave it alone.
Old June 7th, 2019, 16:26   #15
ToxicDoc
TDI(s): 2001 Jetta
a simple tune would be the best bang for the lowest money, but there's a chance your stock clutch won't handle a basic stage 1
ToxicDoc is offline   Reply With Quote
03 MKIV Golf TDI heat problems 03golftdi92 VW MKIV-A4 TDIs (VE and PD) 13 January 27th, 2017 07:18
Low Budget Performance? rrdevos TDI 101 10 September 19th, 2010 17:13
MOD suggestions for $1500 budget? Brasil TDI Power Enhancements 18 January 27th, 2009 21:56
Body mod for MKIV 06 Golf cfunderburg Upgrades (non TDI Engine related) 2 November 10th, 2006 15:48
WTB: New jersey. low budget SingleSpeed TDI Cars for Sale/Wanted 1 October 30th, 2004 15:21
© 1996 - 2020, All Rights Reserved
Page generated in 0.17180 seconds with 11 queries
[Output: 125.16 Kb. compressed to 104.39 Kb. by saving 20.76 Kb. (16.59%)]
