Old April 29th, 2019, 21:09   #1
deadlyaztec
TDI(s): 2015 Passat
Default How to remove central console
Hello I been trying to trying to find a video or pictures on how to remove the center console on a
2015 tdi. I been searching for a few days and I havenít found anything. Iím planning to run some usb cables to the glove box for my new stereo.
Thanks.
deadlyaztec is offline   Reply With Quote
Old April 30th, 2019, 09:55   #2
Strider17
I know the cup holders pop out. As well as the rear vents. This exposes some bolts.
The trim that runs across the glovebox, radio and behind the steering wheel has to come off to remove the glove box.
Few bolts and under the steering wheel and glovebox as well.
That’s all I know.
Strider17 is offline   Reply With Quote
Old April 30th, 2019, 10:03   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Take the seats out. That makes it much easier to access the little plugs on each side that cover the screws. There is another screw on each side in the footwell area. That gets the side pieces off, then the rest comes back up and out.
You have to pop the front trim piece up and off first, the one that goes around the shifter and parking brake lever, as well as the rear vent.
Seriously, though, it would be a pain-to-impossible with the front seats in place. They come out fairly easily. Take the headrests off first, so you have clearance to lift them out of the car. Be careful with the plugs underneath... some can be fragile if you do not release them properly.
oilhammer
www.cardocautomotive.com
How do you Remove Center Console to fix Cup Holder? PAJettaTDI VW Passat Family (NMS and B7) TDIs (2012+) 5 December 27th, 2017 12:41
How to remove center console cigarette lighter wincharger TDI 101 1 January 30th, 2014 09:53
Easy how to remove Arm Rest and Newer centre console witchcraftz TDI 101 0 July 25th, 2012 13:06
Central console rattle BoumBoum VW MKVI-A6 Jetta Sedan (~ 2011+) 1 April 27th, 2011 12:59
How to remove center console (with cupholders) on 05 Wagon? jimnms VW MKIV-A4 TDIs (VE and PD) 0 March 3rd, 2007 20:19
© 1996 - 2020, All Rights Reserved
Page generated in 0.13314 seconds with 11 queries
[Output: 58.87 Kb. compressed to 53.41 Kb. by saving 5.46 Kb. (9.27%)]
