Old September 23rd, 2016, 07:23   #16
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The Aisins use an external TCM. The DSG has an internal one.
I think the Tig's J217 TCM is on the left inner fender somewhere, maybe under the fender liner.
And of course the J492 AWD controller is on the Haldex unit itself in the rear of the car.
oilhammer
www.cardocautomotive.com
Old September 23rd, 2016, 07:45   #17
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
See, that might be another issue, will the tdi ECM communicate with that tcm? that might be a whole other level of issues
2013 f150 Ecoboost 157" WB tuned
2009 Bmw X5 diesel... stock for now
2012 Jetta Tdi Dsg bone stock..for now
2002 jetta tdi 5 speed TD tuned 48.6 avg. SOLD
1999 beetle 5 speed whitbread built. SOLD
2002tdi is offline   Reply With Quote
Old October 14th, 2018, 15:12   #18
kyle_h
I hate seeing these good threads die
2014 Touareg TDI Execline R-Line (current)
2010 Jetta TDI Cup Edition (TDI buyback)
2001 Jetta TDI (retired @ 478,000km)
kyle_h is offline   Reply With Quote
Old October 15th, 2018, 05:08   #19
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
i still want to do it. i just dont want to run into anything crazy.
Old October 22nd, 2018, 11:31   #20
vwztips
vwztips's Avatar
Last year I converted a 2012 Tiguan S, FWD manual to a CR TDI, complete with Mircon2 filter and "upgraded" fuel pump. Donor car was a 2013 Golf with 6 speed.
Mike at TDTuning did the ECU programming.
Marin did the instrument cluster and Immo work.
Mechanically it was a direct swap. Only issue was that the gas cars use different fittings for the intercooler vs TDI and the IC sits 4" higher on the Tig than a Golf or Jetta. So I found the correct IC and plumbing for a TDI Tig from Europe on Ebay.
Definitely doable and worth it. Consistently got 32 MPG in town with my heavy foot and low to mid 40's on hwy.
Currently have a 2011 Tig 4mo. Bought it with a bad chain tensioner and 8 bent intake valves. Got that running.
Picked up a wrecked 2011 Jetta TDI with DSG. Once my 2004 Passat TDI wagon, 4mo, 5 speed manual sells, going to swap the Tig over to a TDI FWD. Have located a 4mo DSG in Europe in case I decide to go the 4WD route once I get the FWD up and running.
vwztips is offline   Reply With Quote
Old October 23rd, 2018, 05:37   #21
bobbiemartin
Originally Posted by vwztips View Post
Last year I converted a 2012 Tiguan S, FWD manual to a CR TDI, complete with Mircon2 filter and "upgraded" fuel pump. Donor car was a 2013 Golf with 6 speed. Definitely doable and worth it.
I bought the Tiguan from vwztips a while back. I've put over 10,000 miles on it It's a great daily driver. We were also using it to pull our Casita travel trailer. It did OK, but have recently bought a TDI Touareg for that.
I get mid 30's for the most part. The best I've got is 39. Mileage drops to 19 towing, but that is still not bad. All in all, it's a great all around vehicle. When we were using it to pull the Casita I was going to convert to 4Motion. I sourced the rear suspension and had bought a TDI 6 speed 4Motion gearbox and transfer box. However, FedEx lost it (how do you lose something that big?). It took several months to get that sorted and we decided to get the Touareg so the 4Motion conversion has been put on hold.
bobbiemartin is offline   Reply With Quote
Old October 29th, 2018, 05:22   #22
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
what did you do about fuel tank and fuel lines?
Old June 4th, 2019, 20:10   #23
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
Back from the dead. Just picked up a 2010 Tiguan 6 speed that is getting a common rail. Is there a year to buy that the harness and pcm will plug in and talk to each other?
Old June 4th, 2019, 20:14   #24
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
Can you message me the person name who did the cluster. And did you use the Tdi or the Tiguan cluster?
Old June 5th, 2019, 13:34   #25
vwztips
vwztips's Avatar
No, there is not a plug and play harness from gas to TDI. There are significant differences between the wire and fuse locations between the 2.
Much better to use a Golf as the wiring and fuse box is closer than the Jetta/Tig
Jetta ,97 (Marin) is the tuner's name that did the cluster work. He wound up using half the Golf cluster and half the Tiguan. The Golf cluster could not read the fuel level correctly since the Tig has 2 senders and the Golf has 1.
For my current TDI/DSG into a Tig project, i purchased a Tig TDI cluster from UK eBay which should resolve the issue. Plus the donor Jetta had a very basic cluster and the current Tig cluster was basic as well.
Just be warned. Wiring is the biggest challenge on this conversion
Old June 5th, 2019, 15:35   #26
Owain@malonetuning
CR harnesses are not for the faint of heart. erwinvw has pinouts but even then the full cars harness barely fits in a 9x5ft area and will take many hours to untangle and depin. Quickly shrinks with deletes and removing body side components but it's a royal pita compared to an alh or pd.
DSG would be awesome, there's one with a euro TC auto floating around on the east coast with awd, guy who built it for the customer is very far off the deep end in terms of ability and shenanigans though.
Owain@malonetuning is offline   Reply With Quote
Old June 6th, 2019, 08:41   #27
vwztips
vwztips's Avatar
Yes but I also found some inconsistencies from what Erwin says and what actually is in the car, in regards to the SB fuse block. Took a while to figure that one out.
The 2012 Tig I am working on is an SEL 4mo. The added bells and whistles are making it interesting just to make sure I am not screwing something up.
Short term goal is to get it running with the Jetta FWD DSG.
Long term goal is to source a DSG 4motion and replace FWD DSG.
common rail F/S ronbros TDI 101 7 August 23rd, 2012 05:11
Common rail noise Gil General VW Discussion 8 August 2nd, 2007 12:30
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
Common rail and biodiesel Michael Pietro Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 14 April 25th, 2006 23:30
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
Page generated in 0.15043 seconds with 11 queries
[Output: 118.33 Kb. compressed to 100.67 Kb. by saving 17.66 Kb. (14.92%)]
