Old August 5th, 2016, 12:09   #1
K Brondbjerg
Red face Strange BV43 turbo performance - suggestions?
I upgraded my Passat 2003 Limousin PD 130 AVF with a P&P BV43 turbo part number 03G145702H / engine codes BRD and BVA
I ordered one of the best performance-pros in Denmark to chip my car, but he toeld that the boost pressure was weak by 2000 rev, and first hit max. pressure 1,5 - 1,6 bar by 2500 revs. :-( - see picture below.
The Nm. is also strange between 2.500 and 3.500, and it is not the same figure every time?
He toeld me that it might be a old katalysator that must be exchanged and/or the BV 43 turbo might be faulty?
Any suggestions?
Ps. I run my car in limp mode (55 Ps) for 1.000 km. before chipping it.
K Brondbjerg is offline   Reply With Quote
Old August 6th, 2016, 03:03   #2
Yucca
Run VCDS Log file, channels 3,8 and 11. 4.gear, Wot, 1500rpm@-> limiter.
Yucca is offline   Reply With Quote
Old August 6th, 2016, 14:16   #3
K Brondbjerg
Thumbs up
Thanks for the suggestion, I will follow up
Old August 8th, 2016, 02:45   #4
K Brondbjerg
Default Weak pump or untight hoses?
I have asked another mechanic, and he toeld me that he has often repaired untight systems or old pumps. There is also some times a kind of valve in between that some times need to be bypassed?
He has first time in a few weeks, but I will report back - Tanks for the help
Old August 15th, 2016, 23:04   #5
Rub87
170hp bv43 I find never spools really good. feels dead below 2k but shines at 2k5-3k5.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old June 10th, 2019, 02:49   #6
Ricsi168
Hello guys!
Sorry to wake up an old thread,but i think i have got the same strange things!
My car is 2003 audi a4 b6 1.9pdtdi AVF quattro 6 speed manual
With:
Bv43 from 170pd
Front mount intercooler
Egr off
Cat off
Kevlar clutch
Vac system simplyfication
My problem is that i have got my vnt system setted who do things like this all day!My emap and imap is nearly the same (like imap=emap+0,5bar)
Car feels dead under 2000-2200rpm....
i read with this turbo you can get nearly 200hp,but my can feels like i have got no turbo...its not that strong
i can post my ecu files and logs if thats help!
Ricsi168 is offline   Reply With Quote
Old June 11th, 2019, 00:16   #7
Yucca
How much EMP at idle? 0.2bar is good adjust for stop screw.
What is AFR level when turbo is spooling up?
Old June 11th, 2019, 21:29   #8
adamss24
Fuel Economy: 35-45mpg
You wont get that good boost response from a bv43, i suggest you get a bv43a cartridge and swap it in, it has a billet compressor wheel and an extra set of blades compared with the pd170 bv43. With a bit of adjusting the duty cycle and PID you can get satisfactory spool from a kkk bv43 turbo just dont expect wonders ! As others said they do shine in midrange...
adamss24 is offline   Reply With Quote
Old June 16th, 2019, 08:09   #9
Ricsi168
Hello guys!
Yes i know about spool i dont want to spool as fast as 1749va but i think mine spools even worse i think i got 1bar at 2000 rpm.
At the moment i dont know about idle speed exhaust manifold pressure but how can i adjust the stop spcrew professionally ? At idle speed with watching emp adjust screw to read 0.2bar?
About the afr i dont know how can i check that from the software? I got a little black smoke when doing wot 3rd gear to 4000rpm.
And also rod lenght settings is question, with 4000rpm how much percentage is good to have in n75 readings i think now i got something like 74%
How can i check or adjust pid control?
Old June 21st, 2019, 10:47   #10
bhodgkiss
Mine pulls strong from 2200rpm ish
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old June 22nd, 2019, 02:20   #11
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
Gtc1549 īs Best for the money..
Ofcourse not p&p
Lucian189 is offline   Reply With Quote
Old June 24th, 2019, 08:19   #12
Ricsi168
Anyone has some suggestion how to reduce lagg below 2000rpm? Apart from turbo change.
Old June 25th, 2019, 06:04   #13
Yucca
Ofcourse not p&p
Hows that so much different? Both stock turbos from 170bhp engine.
Old June 25th, 2019, 13:08   #14
Ricsi168
Hello guys!
aT the moment im making an emp adapter and guge to read emp.
I searched on this forum about vnt stop screw setting i got some news, when the tester is ready i will check for(forum writes 0.2bar amp at idle,and at 2000rpm in neutral my turbo should make 2-4psi)
Any suggestions about or anything i should check too?
And an other question how much emp is bad when the vanes are closed and accelerate the car?
Old June 25th, 2019, 16:17   #15
jimbote
jimbote's Avatar
swaps right into the pd170 bv43 exhaust housing? what about compressor housing ? thanks!
Fs: Bv43 turbo duke21 Private TDI Items for Sale/Wanted 20 July 7th, 2017 05:19
WTB: BV43 Turbo K1Cowboy Private TDI Items for Sale/Wanted 5 January 4th, 2015 08:52
Want to Buy BV43 Turbo FlyingFin Private TDI Items for Sale/Wanted 15 December 18th, 2014 09:34
Which is the right BV43 turbo? bhodgkiss TDI Power Enhancements 1 November 16th, 2010 10:29
BV43 turbo ERE TDI 101 1 October 27th, 2008 07:33
© 1996 - 2020, All Rights Reserved
Page generated in 0.15919 seconds with 11 queries
[Output: 122.97 Kb. compressed to 102.23 Kb. by saving 20.74 Kb. (16.87%)]
