Old June 8th, 2015, 13:25   #1
TDITransporter
TDITransporter's Avatar
Default VNT 17/22 Smokes a bit Much Acceletaing
I installed a 17/22 recently in a 98 AHU with Malone tune stage 2. I'm using Bosio DLS1019 injectors. I notice when I shift into 3rd especially, I get a lot of smoke for a couple of seconds. Or when I accelerate hard.
I didn't get this with my K14 turbo, same tune.
During acceleration I'm seeing about 16psi boost. My ECU will top out at 21. Any ideas as to getting rid of the black smoke during acceleration?
I do like the power band and low EGT's
TDITransporter is offline   Reply With Quote
Old June 8th, 2015, 14:10   #2
Lex4TDI4Life
Lex4TDI4Life's Avatar
That's a pretty different turbo compared to your old one. I would wager you need to be retuned.
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old June 8th, 2015, 15:39   #3
TDITransporter
Oh it had to be re-tuned. The k14 is a waste gate turbo, and the VNT is vacuum controlled. I have to use the N75 valve to run the VNT.
The power is good just the black smoke at throttle.
How about more boost? Would that help with the smoke?
Old June 9th, 2015, 02:37   #4
UhOh
UhOh's Avatar
Too much fuel or not enough air, take your pick. Sounds like you need to concentrate on your low boost issue.
WTB: VNT 17/22 or 22 bits to make... Votblindub Private TDI Items for Sale/Wanted 1 February 13th, 2015 06:10
WTB: Lightly used good working vnt 17 or 17/22 maybe vnt 15 jettaboosttdi Private TDI Items for Sale/Wanted 3 March 16th, 2013 15:55
WTB: Turbo - VNT-17/22 or VNT-17 shadows Private TDI Items for Sale/Wanted 7 June 8th, 2012 07:52
Turbo Sale @ kermaTDI 17/22 , VNT-15, VNT-17 VailPowder Vendor & GroupBuy items for sale 6 April 14th, 2012 18:10
WTB: VNT 17 or VNT 17/22 and relate nozzles. Roving TDI Private TDI Items for Sale/Wanted 0 June 26th, 2010 20:16
Page generated in 0.14885 seconds with 11 queries
[Output: 63.77 Kb. compressed to 57.09 Kb. by saving 6.68 Kb. (10.47%)]
