Go Back   TDIClub Forums > FAQs (Frequently Asked Questions) > TDI Maintenance
TDI Maintenance Archives on TDI Maintenance related items.
Old April 14th, 2010, 22:44   #256
bassewitz
bassewitz's Avatar
Fuel Economy: 6.7L/100km city
Originally Posted by bassewitz
I have been gathering all my service records for the potential buyer and while scanning in some of the major ones I noticed that the vacuum hoses were replaced during the last major repair. I would post the entire report but at this point I am actually more interested if anyone thinks that this even qualifies as a limp mode or if this is something different.
Thank you everyone for your input.
I just heard back from the buyer of my car. He owns a shop that fixes fuel injection pumps and turbos.
The final result was not any vacuum leaks or electrical shorts. Here is what he told me:
"The injection pump and injectors were removed and tested: the pump fuel output was approx 5% low, and the injector opening pressure was low, with one injector having a partially blocked spray hole. We re-calibrated the injection pump to the top of spec, and installed new nozzle tips in the injectors."
Yes, the dealership had tried that something similar.
"[...]ran vehicle with separate fuel supply connected directly to injection pump, bypassing vehicle fuel supply system, [...] swapped good injector from a donor vehicle [...]"
Not sure why it worked now. My loss, his gain.
bassewitz is offline   Reply With Quote
Old April 20th, 2010, 18:35   #257
snobum13
snobum13's Avatar
Fuel Economy: 44.3
I am getting a buzzing/humming noise from my N75 valve that is somwhere between a bumble bee and a humming bird sound. Replace it? To be more specific I get the noise directly after turning the car off.
snobum13 is offline   Reply With Quote
Old April 21st, 2010, 17:32   #258
BigAndy
TDI(s): 99 A3
Default Make this thread a STICKIE!!!
This thread should be STICKIE....maybe I'll start a poll!!
On many long journeys have I gone. And waited, too, for others to return from journeys of their own. Some return; some are broken; some come back so different only their names remain.
BigAndy is offline   Reply With Quote
Old April 28th, 2010, 09:54   #259
Thorne
Thorne's Avatar
My limp mode issue evolved into a more serious problem with the check engine light coming on, and isn't fixed for more than a few minutes by cycling the ignition.
Guess it is the MAF or possibly the N75, and will take it into Tomas Sport Tuning late this afternoon for work tomorrow. Will update thread when I get it fixed...
03 Jetta 5-sp Wagon 207k, running min. 2% biodiesel, Turbocharger Pros new turbo, Curt towbar, Weathertech cargo liner, Husky floor liners, Aspherical/Convex mirrors.
PAST VW's - 63 Beetle, 2x 69 Poptop Westfalias, 87 Golf 4-dr 5sp (converted for righthand drive in the UK ), 89 Golf 4-dr 5sp.
Thorne is offline   Reply With Quote
Old April 29th, 2010, 16:16   #260
Thorne
Thorne's Avatar
Per Tomas Sport Tuning it was the N75. If that turns out to not be the fix, I'll update this forum.
Old April 30th, 2010, 05:43   #261
pepper10
Fuel Economy: 46 Avg
Default unexpected limp mode cause...
I just wanted to chime in after I found the cause of my overboost situation. I was getting limp modes every time I would accelerate past 2500 rpm in 3rd, 4th and 5th gears. Virtually no turbo presence to mention of at all times. I got started with diagnostics with this thread (thanks CDN Griz!) I have a 2002 Jetta 225k miles with rocketchip stage 1, stock turbo. With the miles on the car, I opted to change all the vacuum lines. No effect. Test the N75 with Vag Com. It's dead. Swap it for the N18. Dead too. I changed the N75 (EGR is deleted so I didn't bother with the N18). No effect. Hmmm . Hook up a vacuum pump to the VNT actuator. Can't pull a vacuum, IE the rod doesn't move at all. Bad actuator or stuck turbo vanes? I take a chance with the actuator and order one. Bingo! The old actuator was stuck.. the rod came loose from hitting it on the ground with a big puff of rusty smoke. I move the rod on the turbo for the vanes and it's moving freely whew! I install the new actuator. No effect.
I am now at wits end. I omitted the vacuum test on the lines Grizzly mentions at the beginning of the diagnostic procedure. So I start checking for vacuum leaks. I found the brake booster line to have cracks in it at both ends. I replaced the plastic line with air compressor line I had laying around. No effect. Then the only source of the problem and the one that cause all the other failures... the boost valve ( http://boostvalve.com ) I installed after the Rocketchip. I unplug it and bang! Turbo is back.
I emptied the intercooler of oil 2 weeks ago, poured almost 2 cups out of it. This oil made it's way into the line leading to the boost valve. I took the valve apart to clean it and black particles of dried oil came out. I did the same with the line... even worse. I hope this experience can help others...
It's a Diesel thing...ladida
pepper10 is offline   Reply With Quote
Old April 30th, 2010, 18:02   #262
martytdi
I'm done with trying to fix this limp mode issue..Picking up new 2010 Jetta TDI sport wagon DSG Trans..I hope it will be some time before I have any issues...
99.5 was getting bad.
martytdi is offline   Reply With Quote
Old May 2nd, 2010, 20:32   #263
werdna
Location: An obscure corner of northeastern Massachusetts, USA
Related question on this: is just cycling the ignition switch while driving otherwise bad for the engine? My owner's manual ('03 ALH) makes a big point of not bump-starting the car, but warmed up and turning at 2k rpm might be a different story. Any opinions?
The one time I've needed this, I idled it, shut it down, then used the starter to bring it back and let it stabilize at idle before picking up the load again. More than happy to hear I'm being paranoid here!
'03 Jetta Wagon TDI, '87 Golf gasser (make an offer!), and too many others
werdna is offline   Reply With Quote
Old May 2nd, 2010, 20:41   #264
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Not hard on it at all... drive more, worry less!
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old May 16th, 2010, 23:48   #265
jimbo1981
jimbo1981's Avatar
Fuel Economy: 5.1 litres/100km
Mine was REALLY simple but caused ALOT of delays and heartache coz I didnt have a diagnostic unit! All it was, was a faulty connection to the injector sensor - when I finally found a place that could read the trouble codes (Zimbabwe is tough!) they repaired the connection and cleared the trouble code. All back to normal
jimbo1981 is offline   Reply With Quote
Old May 18th, 2010, 07:41   #266
coronan
TDI(s): 01 Golf
Fuel Economy: 44 - 52 mpg
I have a very situational limp mode isue (po234): It happens on 2 occasions almost the exact same place.
1. Hill climbing at high altitude (about 8,000ft); about 60-70% throttle, 15psi of boost.
2. After engine breaking (coasting down hill in gear)
I believe my tune is good for 18psi. My boost valve stops a spike at 21 and regulates sustained boost at 19psi. I cant get it to hit limp mode at full throttle.
Last summer I replaced all vaccume line and n75 valve and replaced the MAF. My acutator will blead 1" vaccume over 5 or 10minutes.
Any ideas?
01 Golf, 180K mi, 2R520, Malone Tune, 2052, 3" DP-Cat-exhaust, IE Rods, Head Ported by Franks TDI, ASV Pistons, SBC Stage 2, Stealth EGR, Carter p4070 lift pump, Ebay FMIC, 11mm, 3" TIP, WaveTrac, DIY Rear Sway, Custom Intake Mani, Dog-bone Shimmed, 4"snorkel, Stanadyne FM100 5 mic, T-belt tools & VCDS,
coronan is offline   Reply With Quote
Old May 27th, 2010, 18:16   #267
coronan
TDI(s): 01 Golf
So I threw a p0234 code again today. This time I pulled a log in vag com before clearing it.
Here it is:
Tuesday,09,March,2010,17:30:45:51785
VCDS Version: Release 908.1
Data version: 20091018
Readiness Status: 00000000 00000111 10000000 00000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
Tuesday,09,March,2010,18:29:16:51785
Address 01: Engine (038 906 012 CP)
18:29:10 Group 003: EGR
903 /min Engine speed 870-950 rpm
500.0 mg/str MAF (specified) 230-370 mg/H
425.0 mg/str MAF (actual) 230-370 mg/H
4.8 % EGR duty cycle 40-75%
18:29:10 Group 011: Charge Pressure Control **Done at WOT**(See label file)
903 /min Engine speed rpm
999.6 mbar Specified MAP 1850-1950 mbar
867.0 mbar Actual MAP 1700-2080 mbar
19.9 % D.cycle MAP v. 45-95%
Thursday,27,May,2010,17:05:45:51785
Freeze Frame Data for address 10
PID02 DTC that caused freeze frame data storage: P0234
PID04 Calculated load value: 49.0 %
PID05 Engine coolant temperature: 86 ∞C
PID11 Intake Manifold Absolute Pressure: 154 kPa abs
PID12 Engine RPM: 2094 /min
PID13 Vehicle speed: 91 km/h
PID14 Ignition timing advance for cyl #1: 10.0 Degrees
PID15 Intake air temperature: 34 ∞C
PID16 Mass Air Flow: 51.20 g/s
PID17 Throttle position sensor: 47.8 %
Yes that's 22 psi of boost *** BUT *** The mc nally boost gauge only recorded a spike of 13 psi.
The group 11 Actual Map mbar of 867 is appropiate for my altitude. (the sensor is working. I think)
So which gauge is right? stock map or Mc Nally??? The mc nally gauge is less than 1 year old and shows appropriate values at full throttle.
I wish I could see what N75 cycles were leading up to the event.
...Buler?
Old June 4th, 2010, 08:43   #268
Thorne
Thorne's Avatar
Hopefully got a final fix on my mysterious overboost / limp mode problem -- Tomas cleaned out quite a bit of caked sulphur from the intake area. After a little testing I'm unable to get it to fail once warmed up at high RPM's, where before I could get it to replicate pretty well on my 100 mile commute when punching it hard above 70mph. It also would fail when towing up steep grades with heavy acceleration.
So, after replacing the MAF (just on spec = my idea), N75, and testing all the vacuum lines, it looks like gunk buildup on the intake side was to blame.
As before I'll update this Forum if it turns out to be anything different.
Old June 21st, 2010, 23:29   #269
taugust
TDI(s): 2002 Jetta
Well, I will relate my experience and see if anyone can help. I may help someone else in the process. BTW, thanks for all the extremely valuable input. This site has saved me thousands.
I read this thread several times. Was having limp mode, mostly without throwing a code, on long hill climbs. I have several on my 100 mi. RT commute. Occaisionally got 1556.
2002 Jetta, 237K miles. Snow screen removed.
I started going through the procedure.
Checked MAF with Vag-Com and replaced MAF. Slight improvement in power, still have limp.
Check vacuum with Mityvac at N75. About 24" Hg.
Test N75 with Vag-Com. OK
Test Actuator with Mityvac. OK, holds vacuum. Adjustment appears to be in spec. Turbo moves relatively freely with no real bind through entire range of motion. I have had the turbo off several times (every 6 mos., but not since 1/2008) for carbon buildup cleaning after running B100. Now run about B20-B40. That failure was different and I got where I could feel it coming on. It would throw a CEL consistantly. Switch to petro 100 for a month or two cleans it out.
Run LM Diesel Purge. Replace air filter (had K&N since about 88K mi.) Glow plug harness (was getting consistant codes), fuel return lines, vacuum lines with McMaster silicone (except for rubber line to turbo (ran out of line). Slight improvement in power, still have limp.
Replace main vacuum hose to brake booster after finding a split in the hard plastic line at the check valve. Virtually no change.
Clean intake and intercooler. Heavy carbon buildup in EGR and intake manifold. Very small amount of oil in intercooler (EGR cycle recal at 119K mi.) Found 66% missing gasket on driver's side of exhaust cooler. This was causing a whoosing sound on accel. Replaced. Whoosh sound fixed, signficant improvement in low-end acceleration. Turbo whistle is good. Boost guage shows up to 16 psi. So far, no more limp mode.
Now, the reason for my post. While the car has significant improvement in low-end accel., it still feels sluggish on the long hard hill climbs. It will do 75mph, but cannot accelerate up the hill, even at WOT, like it used to. I have verified all is well on the intake side. My next thought is some sort of restriction in the exhaust. Thoughts?
Thanks for all your help.
taugust is offline   Reply With Quote
Old June 22nd, 2010, 09:05   #270
Tom W.
Tom W.'s Avatar
Fuel Economy: Getta 49MPG IDI 60MPG Passat 34mpg
Default Clarification:
So, you are boosting 16PSI while going up that hill, WOT, and can't accelerate? ?
Please clarify...........
Chemically cleaning your turbo: http://forums.tdiclub.com/showpost.p...8&postcount=48
canadiangrizzly's Diagnosing limp mode: http://forums.tdiclub.com/showthread.php?t=179589
GoFaster on loss of power:
http://forums.tdiclub.com/showthread.php?t=75959
Tom W. is offline   Reply With Quote
Diagnosing and Fixing Limp mode for A4 1.9TDI [low power troubleshooting] Canadian_Grizzly TDI 101 600 June 13th, 2019 12:23
Audi A4 Low power and limp mode and other problems arijus TDI 101 5 August 9th, 2018 15:34
Low power,limp mode vrus13 VW B5 Passat TDIs 6 October 30th, 2012 09:26
Low Power, no limp mode TDIBrandon VW MKIV-A4 TDIs (VE and PD) 6 February 27th, 2012 04:44
First time diagnosing low power / 1x/limp kiva822 TDI 101 35 July 30th, 2011 05:10
Page generated in 0.16882 seconds with 11 queries
[Output: 138.37 Kb. compressed to 117.08 Kb. by saving 21.29 Kb. (15.39%)]
