Old November 1st, 2016, 07:09   #376
clove5
clove5's Avatar
Fuel Economy: 43-45
Finally got the general grabber at2 205 75r15 I wanted to fit my DIY 3" lift.
The bottle is 10" tall. I have about 10" clearance in the front and 11"in the rear
Sent from my SM-G920V using Tapatalk
99.5 golf 1.9l, white, two door Fuel Economy 42 Mods , DIY 2" lift, Bilstein TC sport strut & shock kit, Moog front VR6 and rear Wagon Springs, Malone tune, egr delete
clove5 is offline   Reply With Quote
Old November 21st, 2016, 19:59   #377
mintyepicness
TDI(s): 03 Golf
Tires look good. I wish they made the Blizzak's a size up for 15's that would work. 205/65/15 is all I find. What did the tires and lift do to your mpg?
mintyepicness is offline   Reply With Quote
Old December 26th, 2016, 08:27   #378
clove5
clove5's Avatar
Fuel Economy: 43-45
I haven't calculated mpg yet. But it takes a lot more energy to turn the wheels.
If general made a 205 65r15, i would get those instead
Old January 23rd, 2017, 22:23   #379
The4ork
The4ork's Avatar
Is there any off the shelf parts from lowes or home depot I can get for the front spacer? Like 1" black Iron pipe or something like that?
The4ork is offline   Reply With Quote
Old February 9th, 2017, 11:45   #380
Was a fordie
I wonder.. if i installed this:
http://www.kermatdi.com/1-inch-lift-...l-new-beetles/
and then put Bilstein HD Gas shocks or similar KY-B shocks, would I then net about 2 inch lift.?
Was a fordie is offline   Reply With Quote
Old February 9th, 2017, 11:53   #381
oldpoopie
oldpoopie's Avatar
Wont work. Any of the lift kits that use spacers like that can NOT use Bilstein HD front struts. The HD has a larger strut tube so the spacer will not fit.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old February 9th, 2017, 12:06   #382
Was a fordie
oh really, what shocks would then?
Old February 9th, 2017, 15:58   #383
oldpoopie
oldpoopie's Avatar
Anything else with a strut tube the same dimensions as factory
Old June 5th, 2017, 17:20   #384
Gluckmysock
Well, Finished my budget lift. The 2"x4" bushing was found here: www.supplyhouse.com I also picked up a piece of 2" pipe 3" long and cut it in half. The strut spacers are 1" black pipe cut 2" long. The shock spacers were from 1"x1" square tubing from lowes. I drilled and fitted everything, then had it powder coated. Should survive many salty PA winters. Tires should be on this week.
2002 Jetta TDI. VNT17 w/ Stage 4 Malone Tune. Custom gauges.
Gluckmysock is offline   Reply With Quote
Old June 10th, 2017, 18:21   #385
Millennium Falcon
looking good man!
[QUOTE=Gluckmysock;5288542]Well, Finished my budget lift. The 2"x4" bushing was found here: www.supplyhouse.com I also picked up a piece of 2" pipe 3" long and cut it in half. The strut spacers are 1" black pipe cut 2" long. The shock spacers were from 1"x1" square tubing from lowes. I drilled and fitted everything, then had it powder coated. Should survive many salty PA winters. Tires should be on this week.
2003 Jetta TDI wagon, 5-speed, swap, Sprint520 nozzles 165k
2004 passat 1.8t auto 104k
1949 Willys cj3a ALH tdi swap
Millennium Falcon is offline   Reply With Quote
Old June 11th, 2017, 03:31   #386
Gluckmysock
Thanks Man! Appreciate it.
Old June 13th, 2017, 15:02   #387
hey_allen
Ok, I've been watching this thread for a good while, and had a question that I don't remember having seen yet.
How much of a difference do the larger tires make in the daily driving behavior, when you go from 195/65-R15 to 205/75-R15?
I did some digging and looking at the ratios/speedometer error numbers, but am curious if anyone has personal experience that they would share.
My car is stock at the moment, but as soon as I can find my timing belt tools, is going to be getting an 11mm pump, Sprint 520 injectors, and a Malone stage 3 tune, so I'll have some increased torque to play with.
I've already replaced one oil pan, and don't want to replace another. This led to my plan to lift the car at least 1", but might go for a 2" lift and the larger tires, depending on drivability.
hey_allen is offline   Reply With Quote
Old June 13th, 2017, 16:16   #388
Gluckmysock
I have my tires, 215/75/15 air pressure set to 40 on the front and 35 on the rear.
Car rides very nice and smooth. Handles very well.
I'll probably drop the front to 37-8 and the rear to around 33. Only because I thinks the air pressure is just a little to high.
Old June 15th, 2017, 15:36   #389
Gluckmysock
It's all about that flex!
Old June 15th, 2017, 17:28   #390
Millennium Falcon
Hey Allen, My car is axacly the same as what you describe... I have 11mm pump, sprint nozzles and stage 3 tune. I am running 215/75-15 grabbers. I love them but they definitely do throw off the gearing. It still has the power to turn them but it take a bit of a hit. I notice that I am always between gears unless I really want to put the boost to it. Then it doesn't really matter.. I only notice it when Im just chugging along and I come to a hill. I dont want to always have to hit 20lbs of boost to hold a gear on a hill. I didnt have to with the stock tires, but I do with 215's. I also dont love how close they are with a 2" lift. I loved my rear mud flaps, but cant fit them with the big tires. That being said. The grabbers ride/handle fine, they look AWESOME, the clearance is great, and the lower RPM on the hyw is nice. This is just my .02. I hope it helps.
Page generated in 0.16165 seconds with 10 queries
[Output: 129.69 Kb. compressed to 108.25 Kb. by saving 21.44 Kb. (16.53%)]
