Old June 18th, 2019, 01:13   #1
Jasengine
Jasengine's Avatar
Fuel Economy: 54mpg average
Default Tuning a 2.0TDI 140 PPD with DSG
Has anyone had a successful remap with the BKP engine with a DSG box?
I have the Darkside EGR & cooler delete with the turbo hard pipe kit. Turbo Dynamics hybrid turbo good for 220bhp (GT22 billet compressor, trimmed turbine, upgraded thrust bearing etc).
I had a remap some years ago, but unknown at the time the vacuum valve box response was slow. I have recently changed it to a N75 valve and the boost response is very quick, but the tune is unstable and has strange over-boost and fuelling under certain load and rpm conditions, which I have to keep an eye on the boost gauge to correct. I've checked for a sticking VNT actuator, but on installing the standard MAP, shows perfect boost response under all revs and load conditions, so I don't see the hybrid turbo being an issue.
Two independent well known tuners have declined to tune this setup, one because it has a 'hybrid' turbo and the other because of the extent of the programming for 4bar MAP etc (not installed yet)... Maybe the DSG has an influence on tuning here?
So I am now running the standard MAP which is slow and boring together with the engine check lights flashing at me! This can't be a 'one-off' impossible setup....can it?? Or does everyone keep clear of the BKP with DSG and hybrids
Jasengine is offline   Reply With Quote
Old June 21st, 2019, 14:42   #2
adamss24
Fuel Economy: 35-45mpg
Ditch the rubbish TD hybrid and get a serious turbo in there ! I see they still selling them archaic gt compressors and still clip the turbine blades to stop boost creep! You dont need a 4 bar map sensor with that turbo, it wont be pushing any more than 1,5-1.7 bar of boost ! And for your information, almost every VAG VNT turbo has a "upgraded" trust bearing !
adamss24 is offline   Reply With Quote
Old June 21st, 2019, 22:43   #3
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
Stock 1749vc turbo can handle 1.7b
duke21 is offline   Reply With Quote
Old June 22nd, 2019, 00:52   #4
Jasengine
Jasengine's Avatar
Interesting comments guys.
It's mapped for 1.79barand a wot will settle at 1.7. It will spike to 2.2bar though.
I had a 1756 hybrid from TD may years ago on a 1.9 ALH, with no boost issues what so ever. So I am a little sceptical about this labeling of hybrids being crap. Perhaps they've been given a bad name by cheap builds off eBay??
Old July 3rd, 2019, 14:09   #5
adi_mazilu
I can help you
adi_mazilu is offline   Reply With Quote
Old July 4th, 2019, 16:25   #6
adamss24
Trimming the turbine is a cheap way of trying to hide a poorly matched compressor to a small turbine and limit the surge- wont do much to stop spikes ! Either get a new,matched turbine or get a gtb turbo and tune that !
Alh has a archaic edc15 ecu with a lot less maps for n75 that's why you felt no issues then with the larger hybrid...edc16 is a lot more sofisticated and reacts a lot quicker compared with edc15...
As i've built over 100 hybrids i can guarantee you that the td hybrid is crap, seen their work before...had a crap one on a 2.5 v6 tdi (!), also every garret turbo from gt1749v on has an upgraded trust bearing ! They're passing 20 years old tech as being novelty !
Old July 5th, 2019, 02:25   #7
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
haha - Chris the worse part is they sell them as 240hp units (at least for the 1.9's) - CW from a BMW 530d basically on stock TW.
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
YouTube Channel
Bobby Singh is offline   Reply With Quote
Old July 7th, 2019, 12:32   #8
adamss24
I know Bobby, that's why i told the OP to change his turbo before doing any more work or spending any more money ! Years ago i bought a car from a fellow forum member, it had large poorly setup nozzles and a md240 turbo from the usual "suspects" ! It was a non runner and upon removal of the turbo i found turbine wheel damaged by shards of metal from failing exhaust manifolds ! I phoned TD and said that i wanted to repair the turbo and they said they don't replace the turbine, they just "clip" the blades to improve spool ! They said i need a new turbo at a tune of over 1200 + VAT ! I just asked why they charge so much for just a compressor change ? It wasn't anything exotic, as you said just stock 56mm compressor... Few months after the incident, two guys i know left Turbo Dynamics and started their own business - Tdi Turbos - then a few years later they've split and each went their way ! One is Craig at tdi turbos and the other is Adam Springer Davidson at Pioneering Performance -which i strongly recommend the OP to get in touch with to fix his poor hybrid !
Old July 9th, 2019, 01:56   #9
Bobby Singh
Adam's manifold/2260 do work well -
Managed to get this from a 1.9 stock injectors etc
Very low emp
Its more geared up for 300hp plus (due to runner sizes) - soon will have larger injectors.
BSR
YouTube Channel
Old July 9th, 2019, 22:56   #10
adamss24
That's nice to see ! Thanks Bobby for sharing with us your finds !!!
Old July 10th, 2019, 00:59   #11
ibizatdi130
on my seat leon bkd I use a 4 in 1 manifold found on ebay with gtb1756vk with mfs cw. Before I have try gt1852v and it was a crap, next gtb1756 mfs with stock manifold I was having surge problems at low rpm and bad power at hight rpm
now with that 4 in 1 manifold and the same gtb1756vk mfs work realy better than with stock manifold, no surge and spool very quickly at low rpm. I have wraped it and painted with silicon
ibizatdi130 is offline   Reply With Quote
Old July 10th, 2019, 01:25   #12
ibizatdi130
my tuning files is not realy perfect, I need to spend more time on it but but the car work realy better than with stock manifold
Mardi,26,Mars,2019,22:10:20:50725-VCID:74E653DF177D0AE69E-8020,Version VCDS: FRM 17.8.0,Version données: 20170721 DS276.2
03G 906 021 LL,,R4 2.0L EDC G000SG 9185,
,Groupe A:,'011,,,,Groupe B:, Non actif,,,,Groupe C:, Non actif
,,Engine Speed,Boost Pressure,Boost Pressure,Charge Pressure,,,,,,,,,,
,Repère,(G28),(specified),(actual),Control Duty Cycle,Repère,,,,,Repère,,,,
Marqueur,temps, /min,,, %,temps,,,,,temps,,,,
,0.11,1659,1032.0,1080.0,75.4,,,,,,,,,,
,0.27,1638,1032.0,1068.0,75.4,,,,,,,,,,
,0.44,1638,1032.0,1068.0,75.4,,,,,,,,,,
,0.60,1617,1032.0,1068.0,75.4,,,,,,,,,,
,0.75,1596,1032.0,1056.0,75.4,,,,,,,,,,
,0.91,1575,1032.0,1056.0,75.4,,,,,,,,,,
,1.08,1554,1032.0,1044.0,75.4,,,,,,,,,,
,1.24,1533,1032.0,1044.0,75.4,,,,,,,,,,
,1.40,1512,1032.0,1044.0,75.4,,,,,,,,,,
,1.55,1512,1032.0,1044.0,75.4,,,,,,,,,,
,1.72,1491,1032.0,1032.0,75.4,,,,,,,,,,
,1.88,1470,1032.0,1032.0,75.4,,,,,,,,,,
,2.03,1449,1032.0,1032.0,75.4,,,,,,,,,,
,2.19,1428,1032.0,1020.0,75.4,,,,,,,,,,
,2.37,1407,1032.0,1020.0,75.4,,,,,,,,,,
,2.52,1386,1032.0,1020.0,75.4,,,,,,,,,,
,2.68,1386,1032.0,1020.0,75.4,,,,,,,,,,
,2.83,1365,1032.0,1008.0,75.4,,,,,,,,,,
,3.01,1344,1056.0,1008.0,75.4,,,,,,,,,,
,3.16,1323,1056.0,1008.0,75.4,,,,,,,,,,
,3.32,1323,1068.0,1008.0,75.4,,,,,,,,,,
,3.47,1323,1116.0,1008.0,75.4,,,,,,,,,,
,3.64,1344,1248.0,1008.0,75.4,,,,,,,,,,
,3.80,1323,1284.0,1008.0,75.4,,,,,,,,,,
,3.96,1323,1284.0,1020.0,75.4,,,,,,,,,,
,4.11,1344,1308.0,1032.0,75.4,,,,,,,,,,
,4.29,1365,1308.0,1032.0,75.4,,,,,,,,,,
,4.44,1365,1320.0,1044.0,75.4,,,,,,,,,,
,4.60,1386,1332.0,1056.0,75.4,,,,,,,,,,
,4.76,1407,1344.0,1068.0,75.4,,,,,,,,,,
,4.93,1428,1404.0,1080.0,75.4,,,,,,,,,,
,5.08,1449,1416.0,1092.0,75.4,,,,,,,,,,
,5.24,1491,1512.0,1104.0,75.4,,,,,,,,,,
,5.40,1512,1656.0,1128.0,75.4,,,,,,,,,,
,5.57,1554,1692.0,1164.0,75.0,,,,,,,,,,
,5.72,1575,1740.0,1200.0,75.4,,,,,,,,,,
,5.88,1617,1848.0,1236.0,75.4,,,,,,,,,,
,6.04,1659,1992.0,1284.0,75.4,,,,,,,,,,
,6.21,1701,2124.0,1332.0,75.8,,,,,,,,,,
,6.37,1743,2196.0,1392.0,75.4,,,,,,,,,,
,6.52,1785,2244.0,1452.0,73.8,,,,,,,,,,
,6.68,1827,2244.0,1524.0,71.8,,,,,,,,,,
,6.85,1890,2256.0,1620.0,71.8,,,,,,,,,,
,7.01,1932,2532.0,1692.0,75.4,,,,,,,,,,
,7.17,1995,2724.0,1988.0,71.4,,,,,,,,,,
,7.32,2037,2760.0,2120.0,67.9,,,,,,,,,,
,7.49,2100,2796.0,2324.0,66.7,,,,,,,,,,
,7.65,2184,2832.0,2416.0,66.7,,,,,,,,,,
,7.81,2247,2868.0,2596.0,67.5,,,,,,,,,,
,7.96,2310,2880.0,2740.0,61.2,,,,,,,,,,
,8.13,2394,2904.0,2896.0,58.8,,,,,,,,,,
,8.29,2478,2928.0,2928.0,55.6,,,,,,,,,,
,8.44,2541,2940.0,3048.0,49.3,,,,,,,,,,
,8.60,2604,2940.0,3060.0,39.1,,,,,,,,,,
,8.77,2709,2940.0,3060.0,34.7,,,,,,,,,,
,8.93,2772,2940.0,3060.0,35.1,,,,,,,,,,
,9.09,2856,2940.0,3060.0,35.1,,,,,,,,,,
,9.24,2940,2940.0,3060.0,34.3,,,,,,,,,,
,9.41,3024,2940.0,3060.0,33.9,,,,,,,,,,
,9.57,3108,2940.0,3024.0,32.7,,,,,,,,,,
,9.73,3192,2940.0,3012.0,30.8,,,,,,,,,,
,9.88,3255,2940.0,3024.0,28.4,,,,,,,,,,
,10.06,3360,2940.0,3024.0,27.2,,,,,,,,,,
,10.21,3423,2940.0,3000.0,26.4,,,,,,,,,,
,10.37,3528,2940.0,2964.0,25.3,,,,,,,,,,
,10.53,3591,2940.0,2952.0,24.5,,,,,,,,,,
,10.70,3675,2940.0,2928.0,24.5,,,,,,,,,,
,10.85,3738,2940.0,2904.0,23.7,,,,,,,,,,
,11.01,3822,2940.0,2892.0,23.3,,,,,,,,,,
,11.17,3885,2940.0,2880.0,22.9,,,,,,,,,,
,11.34,3969,2940.0,2868.0,22.5,,,,,,,,,,
,11.49,4032,2940.0,2844.0,22.5,,,,,,,,,,
,11.65,3864,1080.0,2688.0,46.9,,,,,,,,,,
,11.81,3549,1056.0,2220.0,48.9,,,,,,,,,,
,11.97,3213,1056.0,1956.0,51.7,,,,,,,,,,
,12.13,2940,1044.0,1764.0,55.6,,,,,,,,,,
,12.29,2709,1044.0,1608.0,67.1,,,,,,,,,,
,12.44,2709,1044.0,1524.0,67.1,,,,,,,,,,
,12.61,2730,1044.0,1488.0,67.1,,,,,,,,,,
,12.78,2688,1044.0,1464.0,67.9,,,,,,,,,,
,12.93,2688,1044.0,1464.0,68.3,,,,,,,,,,
,13.09,2688,1044.0,1452.0,69.4,,,,,,,,,,
Old July 10th, 2019, 03:24   #13
tdi_my live
TDI(s): Skoda Fabia
Your requested pressure ist till 2300rpm to high.
Set it down, max 100mbar than the Turbo can do.
tdi_my live is offline   Reply With Quote
Old July 10th, 2019, 05:34   #14
ibizatdi130
yes I know that I need to work on my tune but I'm too busy... I think I can also close the vnt a little bite more over 3000rpm, but this time have experienced some problems on this car, leaking gearbox, leaking tandem pump, leaking clutch mastercylinder etc... and I don't know if I want to spend time on that tune when will change for a gtd1756vrk soon...
Old July 11th, 2019, 05:51   #15
Jasengine
Jasengine's Avatar
Thanks for all your info. I'm guessing my setup is not ideal. I've had a tuner look into tuning and had come up against issues with 4bar map mapping and limp mode which would require a lot of work. Not sure what the details are but the Siemens ECU sounds different to the norm...
BMR PD170 Siemens PPD 1.2 tuning kolkmank TDI Power Enhancements 0 July 28th, 2015 01:10
Rough / Wobble when starting some of the time ? 2.0TDi 140 2007 aircanman TDI 101 1 October 25th, 2012 11:56
Turbo upgrade 2.0tdi 140 BKD Edc16u1 TDI Power Enhancements 2 December 21st, 2010 15:48
2005 VW Touran 2.0TDI (140 Hp) Rune J Other VW Group TD(I)s 1 March 16th, 2010 01:18
2.0TDI 140 Pre-Map Essentials? Torque TDI Power Enhancements 11 December 20th, 2008 14:06
Page generated in 0.17643 seconds with 13 queries
[Output: 132.11 Kb. compressed to 111.17 Kb. by saving 20.93 Kb. (15.85%)]
