Old March 24th, 2019, 19:04   #406
ScottRussell
TDI(s): 2007 jetta
Fuel Economy: 10L/100km
Default Lifted jetta
ScottRussell is offline   Reply With Quote
Old March 24th, 2019, 19:05   #407
ScottRussell
TDI(s): 2007 jetta
Old March 26th, 2019, 09:11   #408
vandermic07
Fuel Economy: 47-51 MPG
Scott
Looks really cool!
What size tires and brand are you running?
vandermic07 is offline   Reply With Quote
Old June 8th, 2019, 04:03   #409
GEFP
Interesting read. I'm going to use some of the ideas here.
GEFP is offline   Reply With Quote
Old June 10th, 2019, 12:28   #410
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Fuel Economy: 49 high 44 mix average
Exclamation Alignment
Iíd like to see some alignment spec sheets.
I changed every bushing with exception the the sway bar. Did front subframe when my rack failed. Car is up 2.1 up from 2.3 in rear 2Ē lift from higher AT tires. Is these tires are brand new , the car has been aligned, the rear camber is off slightly. I anticipated odd rear tire wear, it the front inside tires are wearing very fast, probably 60-75 percent of that tread is gone after 5k miles on a 60k tire!
Anyone else having this? Iím m a post this on the FB page.
dhangejr is offline   Reply With Quote
Old June 11th, 2019, 09:40   #411
vandermic07
I just redid the whole front end on my 01 a few months back. Front and rear poly bushings, ball joints, struts/springs with 2" lift, poly top strut mount. I had noticeable inner wear in the front within the first 2 weeks (~1000 miles). The car was also really squirrely in turns and rain.
The toe was out by 1" front to back of tire. (i forgot to check after i was done putting everything back together probably because i had just about everything go wrong on this job and i was fed up!! Rust!!). I just used the tape measure method and got her lined up. No more inner wear!! Ive done various levels front end jobs and never had to touch anything.
Old June 12th, 2019, 11:23   #412
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Iím having the same inner wear issues.
Did you shift your rear beam at all?
I think maybe m gonna have to pay to gave the subframe and rear beam shifted
Old June 12th, 2019, 15:22   #413
jmodge
In my case I had to file the ball joint bolt slots very slightly so camber could be brought back in spec.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old June 13th, 2019, 09:42   #414
vandermic07
dhangejr
Ive never shifted a rear beam. only replaced bushings. rears have camber and will wear on the inners from what i have read. Ive never had excessive wear in the rears. i also think that the rear camber is fixed, but i could be wrong.
Old June 13th, 2019, 21:33   #415
GEFP
There are shims available from NAPA to bring the rear castor back into specs.
Old June 14th, 2019, 09:50   #416
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Iím aware it the shins they were on my plans till I discovered a larger issue.
Boring out the balljoint holes is an excellent idea. Iím going to do this before I take it to get aligned.
I found a shop that says 110$ for an alignment with subframe shift.
Old June 14th, 2019, 10:59   #417
jmodge
Just to be clear, I’m talking about the holes in the lower control arm. I used a round file and a machinist square on the wheel to bring it to a half degree negative camber. It doesn’t take much metal removal. About ,.030” if I recall correctly
Old June 16th, 2019, 13:31   #418
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
The control arm not the ball joint and only a couple of soft passes with a file that it’s the hole loosely
Old August 5th, 2019, 19:12   #419
ScottRussell
TDI(s): 2007 jetta
Old August 10th, 2019, 10:16   #420
ItAintRodKnock
TDI(s): 01GolfTDi
Fuel Economy: 40 with lift
cant find any other information about these... Saw this combo posted in the beef on a budget thread, said to give 3 inch lift. Id like to pair that with Billy HD struts with my Monroe airshocks in the rear to rebuild my current lift.
trying to confirm before i purchase.
It was posted as, jeep JK front springs for our front struts. And Jeep XJ front springs for our rear beam.
What i did come up with is:
Jeep JK- 2007–2018 Jeep Wrangler 2 door
Jeep XJ- 1983-2001 Jeep Cherokee
Part numbers:
JK Front(for VW Fronts)- 52126314AC - $150
XJ Front(for VW Rear) - 52001122 - $96
Summitracing for both, and free shipping looks to be the cheapest I think
Can anyone chime in, would like to get these on order asap if theyre correct.
Sent from my VS987 using Tapatalk
Edit: I guess i was too focused on searching this forum i forgot to checkout google. google does have some results!
on youtube kiddo says he is running TJ springs upfront, and then afew saying JK/XJ as i posted in my questioning.
Im going to checkout the two different front springs closer and pinpoint what is best for me.
From FLA to CO!! 2001 Golf 4 door White: R520, Malone 2, McNally gauge, SB stg2E clutch, Panzer FMJ, FrostHeater, 2white2blue Moog 81055, Bilstein TC-s, homemade "$40 2 inch lift" Long time poster, now just a lurker.
ItAintRodKnock is online now   Reply With Quote
Page generated in 0.16770 seconds with 12 queries
[Output: 122.18 Kb. compressed to 101.77 Kb. by saving 20.41 Kb. (16.70%)]
